Author Topic: Advice on handle repair  (Read 1230 times)
thedon
« on: August 09, 2016, 09:11:46 AM »
Any help appreciated? Does this warrant a new handle? Played with this on sat...didnt feel right, changed the bat mid innings...new bat didnt feel right either lol. Upon flexing the crack seems to open up alittle. Other side is clean.
Re: Advice on handle repair
« Reply #1 on: August 09, 2016, 09:16:54 AM »
Probably worth getting a new handle, prevention is the best medicine and all that (although playing a shot and being left with just the handle in your hand, while the bat flies off further than the ball goes will always have some comedy value).
Also, that grip needs sorting out!  ;)
« Reply #2 on: August 09, 2016, 11:56:26 AM »
Not quite through to the back yet  crack  opens up   its starting  to break  hence increased flex you could do the ping test hit  a ball and listen to the sound of the blade.
Boondougal
« Reply #3 on: August 09, 2016, 02:41:07 PM »
terminal.. buy 2 new bats minimum, it the only cure.
