Author Topic: What To Do With Old Grills?  (Read 2527 times)
« on: August 21, 2016, 01:59:04 PM »
I have couple of old-style Masuri titanium grills sitting in the house. They both received top edged quick balls on the side (as I was pulling) and one of welds has split open. I don't know what to do with them. I am afraid of using them with a loose joint/weld as a ball might sneak thru. Is it possible to fix them? Are the re-usable? Should I just junk them?
Re: What To Do With Old Grills?
« Reply #1 on: August 21, 2016, 05:19:09 PM »
Interested in if there are any answers to this too as got a shed load of Ti grills that need a weld here and there.
iand123
« Reply #2 on: August 21, 2016, 05:36:45 PM »
They'd have a decent scrap value wouldn't they?
« Reply #3 on: August 21, 2016, 05:46:44 PM »
Take them to a metal fabricator. The ti grills can be easily tig welded.
« Reply #4 on: August 21, 2016, 05:56:10 PM »
What is a "tig" weld?
« Reply #5 on: August 21, 2016, 05:59:25 PM »
It's the type of gas used in the welding process
simonmay5
« Reply #6 on: August 21, 2016, 08:49:43 PM »
Have to be gas welded but once they have been done they are as good as new
« Reply #7 on: August 21, 2016, 08:53:09 PM »
This was my initial thought too.
Having consulted the old man he said it is definitely doable, but welding titanium would be a fairly specialist field
« Reply #8 on: August 21, 2016, 08:59:25 PM »
Had the same problem and DIY soldered mine.
« Reply #9 on: August 21, 2016, 09:02:30 PM »
Other than the (obvious?) fact that it wouldn't be as strong as a weld, this sounds a fairly sensible workaround to me - and as you say it can be done more easily
