Author Topic: Size 6 Bats  (Read 2733 times)
Size 6 Bats
« on: August 25, 2016, 03:06:51 AM »
In "1 inch Longer 1 inch shorter" thread, we discussed size-6 bats (http://custombats.co.uk/cbforum/index.php?topic=39828.msg631684#msg631684).
Here are some pictures of the my bats and specs that I can remember. :D
This is my MG-2 size-6 bat with a size-3 blade (6-3) in comparison to my match bat and other SH bats:
The MG-2 6-3 weighs about 2-8 or 2-9. In comparison, my CA match bat weights 2-12.3.
In this picture, you will see the difference between shoulders and handles of the SH bats v/s 6-3 bat:
Blade length difference:
Here is another 6-3, a L&W Reserve in 3-0.2 lb weight:
The ping on the Laver is incredible!
Some 6-3s with an SH CA:
From top to bottom: CA-SM 18 (2-12.3), L&W Private Bin (6-3 configuration, 2-9 lb), MG-2 Rhino (6-3 configuration, 2-8/2-9 lb), L&W Reserve (6-3 configuration, 3-0.2 lb). The Private Bin is supposed to be a "net" bat but it turned out better than some G-1 bats from other bats makers!
In a match situation, I'd take any of the bats pictured here. I am leary about timing so these bats don't see as much action as I'd like to - I just stick with my trusty match bat (CA). If I play a T-20 this season, one of these Lavers is coming out of the closet. :D
avkrish
Re: Size 6 Bats
« Reply #1 on: August 25, 2016, 09:26:51 AM »
@InternalTraining, how much did these smaller bats cost, if you don't mind my asking? Widthwise, are these similar to the full sized bats?
« Last Edit: August 25, 2016, 09:28:26 AM by avkrish »
Re: Size 6 Bats
« Reply #2 on: August 25, 2016, 10:23:11 AM »
So does 6-3 mean it's a size 3 blade with an extra long handle to make the overall length that of a size 6?
« Last Edit: August 25, 2016, 10:51:28 AM by WalkingWicket37 »
Re: Size 6 Bats
« Reply #3 on: August 25, 2016, 11:27:36 AM »
Standard prices and width is the same as an SH bat.
Re: Size 6 Bats
« Reply #4 on: August 25, 2016, 11:29:46 AM »
Yes, that is the idea.
