Pages: [1] 2 3
Author Topic: Myself Batting  (Read 10809 times)
Batbuddy99
  • https://royalascotcc.co.uk
Myself Batting
« on: October 25, 2016, 10:18:39 AM »
Recently, as you all probably know, a bunch of us went to Eversley for a net
I decided to bring a camera along, and filmed the latter section of my first bat
Here is the evidence:
https://youtu.be/Ci6uivIFeFg
Any comments about my technique are appreciated, and I'm already expecting to be sledged about my use of a trigger movement!
I also apologize for the dodgy editing, i havent done one of these before
Re: Myself Batting
« Reply #1 on: October 25, 2016, 10:22:06 AM »
Who's that **** who kept bowling short?  ;)
Re: Myself Batting
« Reply #2 on: October 25, 2016, 10:29:02 AM »
Ah mate
Lovely hand speed through the ball!!!!
It someone pulls that batting apart they need to get a life
You've got a good eye and you give it a good smack
Not a bad start for your cricket career
And the ball landing on your head is pure comic genius
Sivlar13
  • Love a legside stumping.
Re: Myself Batting
« Reply #3 on: October 25, 2016, 10:32:49 AM »
Looks like you're hitting them well mate. You and I have very similar trigger movements in that our front foot moves so our toes move towards the bowler. Be careful not to move it too late as I found my foot gets stuck/I run out of time to get my front foot into the right position. You looked like you had the weight on the ball of your foot though which will help for you to move.
Quality hitting though mate, great tactical and comical use of the top edge!
Instagram - @_theWKcoach
ppccopener
Re: Myself Batting
« Reply #4 on: October 25, 2016, 10:44:19 AM »
comedy gold the ball landing on the lid. We did have a laugh
and er...batting looking better
Re: Myself Batting
« Reply #5 on: October 25, 2016, 11:11:21 AM »
Cam - are you bowling Gas?! Wheeeeeeels
Re: Myself Batting
« Reply #6 on: October 25, 2016, 11:20:44 AM »
Identities of the forumers bowling?
Also needs a warning attached, there is some serious bum cleavage at one point!
Re: Myself Batting
« Reply #7 on: October 25, 2016, 11:45:59 AM »
I came charging in to send down some floaty medium pace! I must have been bowling at nearly the same pace as a test match spinner... :-[
Stuey
Re: Myself Batting
« Reply #8 on: October 25, 2016, 12:00:13 PM »
You asked for a comment and having looked at your vid, I'd picked up that you become open chested on your trigger movement causing your left shoulder to point to mid wicket and your right shoulder to come through. Your in a great position for the ball coming in, I'm guessing you may be caught on the covers or behind mostly. If you wanted to straighten up, lead with your left shoulder into the ball.
Batbuddy99
Re: Myself Batting
« Reply #9 on: October 25, 2016, 12:33:44 PM »
Thanks, interesting, I'll bear that in mind in future
I hadn't thought about that befire
Stuey
Re: Myself Batting
« Reply #10 on: October 25, 2016, 01:03:23 PM »
A simple drill is to put 3 balls down at drivable lengths for on, straight and off drives and practise leading with your head and shoulder into driving each  ball.
ppccopener
Re: Myself Batting
« Reply #11 on: October 25, 2016, 01:08:33 PM »
that's a really good drill that one. It also helps you work out any problems with your grip.
Churchy1989
Re: Myself Batting
« Reply #12 on: October 25, 2016, 10:40:30 PM »
Not picking ok anyone... But compare your self to @WalkingWicket37 you have a good stance, balance, still head! You have a trigger movement before the bank is bowled. Appears to work! Like trott! Would advise working ok your lunges, so you can get forward a bit  more and play under your eyes.
Least you didn't vid your bowling  ;) have a list of things to correct it! Seam up that is!
Re: Myself Batting
« Reply #13 on: October 25, 2016, 10:50:46 PM »
Not picking ok anyone... But compare your self to WalkingWicket37
But harsh mate, he'll have a complex now knowing he'll never be as good me! ;)
Re: Myself Batting
« Reply #14 on: October 26, 2016, 01:26:50 AM »
2:37, you got found out  - slow short ball right into your body.
You trigger forward and put your weight on front. I wonder if you'd be able to rock back to a quick short ball aimed at your rib cage; with your current body alignment, I'd say you'd top edge such a delivery. To any delivery bowled outside the (off-stump) channel, your option is either play a square-drive or slice it to backward-point or third-man. And, that works only if you have a great hand-eye coordination.
I don't know how you bat in a real match situation. If this kind of trigger works for you, then you should continue using it. There are other options as well. :) The reason I say this is because I used to bat like that many moons ago. I have stigmatism in my left eye and did have problems seeing the balls side-on. With practice and better Rx for contacts, I am little better now and bat side-on. My two cents. :)
Pages: [1] 2 3
