Author Topic: What makes a bat hit bigger boundaries even on miss hits?  (Read 4787 times)
sachin200
« on: November 22, 2016, 03:29:20 PM »
1. Is it the bat edges?
2. Weight?
3. Stiff handle?
4. Flexible handle (whip)?
5. Spine size?
6. Batters big forearms now a days?
7. Just pure timing?
8. Batters confidence after the advent of T20?
9. Lack of real good bowlers?
10. Shorter boundaries?
Which factors are scientifically more important than others? Which aren't significant at all?
northernboy1987
Re: What makes a bat hit bigger boundaries even on miss hits?
« Reply #1 on: November 22, 2016, 03:32:43 PM »
I reckon 6,8 and 10 might be the biggest factors.
Mpt7
« Reply #2 on: November 22, 2016, 03:38:04 PM »
1. hand speed
2. base power - stronger batters
3. new hitting techniques i.e power hitting/baseball
4. flatter wickets - more consistent behavior
ppccopener
« Reply #3 on: November 22, 2016, 03:41:29 PM »
overdried bats with big edges, protective equipment for batters(no one is slog sweeping without a lid)
I thing handles are stiffer nowadays
Mpt7
« Reply #4 on: November 22, 2016, 04:00:12 PM »
there's a great video of bairstow, i think, trying to hit 6s with bats from different ears. quite enlightening
alexhilly1492
« Reply #5 on: November 22, 2016, 04:04:46 PM »
Luke Wright did it at hove i think, not a big ground but its interesting to see the difference between different eras of bats.
I think he used, WG grace, Ranjit, Ramprakash and one of his one or something like that anyway. all seem to be brand new bats but made in the same profiles and weights that would have been used
BB: 7-4-9-5, 7.3-0-29-5
Mpt7
« Reply #6 on: November 22, 2016, 04:07:07 PM »
YOU RIPPER!! been looking at Jonny Bairstow's ginger gait for the last 30 minutes!!
https://www.youtube.com/watch?v=IOlaSVoGVrw
« Last Edit: November 22, 2016, 04:11:00 PM by Mpt7 »
alexhilly1492
« Reply #7 on: November 22, 2016, 04:09:14 PM »
YOU RIPPER!! been looing at Jonny Bairstow's ginger gait for the last 30 minutes!!
That's the one!!
sachin200
« Reply #8 on: November 22, 2016, 05:02:25 PM »
The video has one flaw - the bats aren't of same weight. Physics says F=M.a i.e. Force transferred to the ball = mass of the bat x acceleration in the bat speed. It can't be changed doesn't matter what. I don't think it has anything to do with edge size or how big it looks as long as they are of same weight and traveling at the same speeds. May be weight distribution of the bat has a larger effect. If a bat maker make a heavy bat seem light in weight (nice pickup), that is going to help our equation because of higher m and same 'a'.
I think stiffer handles are a hoax. Read the Collision between bat and ball paragraph here.
 http://www.physics.usyd.edu.au/~cross/cricket.html
The impact time is only 0.001 sec between bat and ball. The handle firmness is not going to matter. I know that a few Pakistani bat makers have extra strips of rubber in the handles to make them flexible. Actually it batter to not feel any vibrations in the hand to get a feeling that you have muddled everything. A few professionals take out twine and apply zinc tapes to their handles  For making them slightly more flexible. Again, all it does is prevent your hands from experiencing extra vibrations. On the other hand, stiff handles are going to experience more vibrations. Anyone who has done binding of traditional handles can tell you that one doesn't need carbon inserts for stiffer handles. You can simply use twine - just wrap it extra tight/use more PVA glue to get the same effect (not that it helps in real).
In the end I think it is more about the feeling that a batter gets from his bat other than anything else.
« Last Edit: November 22, 2016, 05:08:43 PM by sachin200 »
« Reply #9 on: November 22, 2016, 05:05:43 PM »
^ Have you ever hit a ball with a bat that has a flexible/whippy handle?
« Reply #10 on: November 22, 2016, 05:06:37 PM »
Where is the "bloke holding it" crowd? There must be something wrong with Luke Wright if he is gives Ranjit bat only a "2".
« Reply #11 on: November 22, 2016, 05:10:54 PM »
11. Pro's practicing range hitting.
« Reply #12 on: November 22, 2016, 05:15:34 PM »
I can't believe altitude and wind speed/direction aren't mentioned...  ;)
sachin200
« Reply #13 on: November 22, 2016, 05:16:26 PM »
Of course that it shouldn't be so whippet that it lags behind (flexes even before striking the ball). It shouldn't bend before striking but at the time of strike, if it is whippy, it doesn't matter. I have tried taking twine off my bats (replacing it by loosely bound zinc tape) & trust me it helps.
There was also a video of Robert Pack on YouTube teaching podshaving to high school kids, standing on his bat handles to show the flexibility/whip of the handles.
sachin200
« Reply #14 on: November 22, 2016, 05:18:18 PM »
Agree - they both matter and so does the speed of the ball faster it comes, the faster it will go by a bat wielded at the same speed.
