Author Topic: Bat weight reduction and effect on performance  (Read 4757 times)
adb club cricketer
« on: January 29, 2017, 05:33:21 AM »
Need some expert opinions on the following three related queries that I always wondered about:
Suppose I have a bat that weighs 2-12 say and sand it down to 2-9 or 2-10 by electric sanding on the face, does it affect the ping of the bat. I know the ping will be affected due to the weight loss, but what I wanted to know is, will the sanding affect the manufacturer's pressing effect/characteristics of the bat so as to degrade the ping?
Secondly, to reduce weight, is it better to sand the face of the bat (thereby risking altering the manufacturers pressing of the bat) or the back of the bat (thereby not affecting the face and the manufacturers pressing on face for the ping)?
Thirdly, to reduce weight by 2-3 oz, is it better to electric sand the bat all the way or use a plane  instead with only final touches left for sanding?
Thanks in advance
Re: Bat weight reduction and effect on performance
« Reply #1 on: January 29, 2017, 08:33:50 AM »
I think you will be sanding for some time to remove 2-3 oz. you want to remove material from the back. I think you should take it to a batmaker to get it done. It's got 'disaster' written all over it otherwise.
Even better, just sell it and use the proceeds to fund another.
« Reply #2 on: January 29, 2017, 08:56:31 AM »
I've done loads
Easiest way is to remove an equal amount from the whole profile, (as long as it's not got a stupid thin toe)
A sander might take longer, but it's probably the safest way.
Electric planers are pretty good too
Best way is to be steady away with the weight removal, don't go stupid on one area
Testing pick up as you go
3 ounce is a lot to remove
My match bats probably had 4ounce off it this way
Ask Pete Hosk, Simon May what the performance is like on it.
Woodyspin
« Reply #3 on: January 29, 2017, 09:57:44 AM »
Not very good facing me i know that much  :D
« Reply #4 on: January 29, 2017, 10:02:29 AM »
Thanks in advance
No sanding to reduce weight  by 3 ounces using an electric sander does not affect the pressing do not sand the face of the bat remove 2 to 3 ounces from the back. Don't use a plane sand with electric sander and finish by hand with fine grit.Dont sand the spine of the bat to assist pickup sand the toe and each side of the spine equally working from the toe To halfway up the bat following he grains It's easy  to do but can be  some what time consuming so  take  your time as removing 3 ounce of wood from your bat is equal to cutting 2 inches off the  bottom  of the bat
« Last Edit: January 29, 2017, 12:15:39 PM by Seniorplayer »
« Reply #5 on: January 29, 2017, 11:02:21 AM »
They are not my match bats!ha
Jnr monkeys got it in nz
« Reply #6 on: January 29, 2017, 11:22:42 AM »
Your match bat that you are hoping to get back from your son unused when he come back from NZ?
Insane performance - light weight and is just ridiculous.
Like a couple of others have stated, I always think it's best to remove any weight from the back of the bat.
tom line
« Reply #7 on: January 29, 2017, 11:27:47 AM »
3 ounces is a lot of wood to get out a bat regardless. It's doable with a sander but will take a long time. Personally I think you are better off, sending it to someone to get it done and removing weight from the right areas to help the pick up and balance rather than trying to get a full 3 ounces out of it
