Author Topic: Doweling Toe  (Read 3037 times)
langer17
Doweling Toe
« on: February 03, 2017, 01:11:57 AM »
Does the size of the dowel matter? Have a canon of a bat that one of the Kookaburra sponsored players at the club had but part of the toe busted off. I glued it back together and have sanded it and it has come up really nicely but I want to dowel it now.
I've done it before (One of Jodie Fields broken bats) with a a bat I didn't really care about as it was SM and ended up using that as a backyard bat, but seeing as this bat is genuinely really good I want to dowel it properly.
« Last Edit: February 03, 2017, 01:13:31 AM by langer17 »
Aussiecollector
Re: Doweling Toe
« Reply #1 on: February 03, 2017, 07:01:40 AM »
Have a look at jpgavans facebook page  he has dowelled many bats , done a lot of repairs for me & his work is outstanding , hell of a keeper that jodie fields
tom line
Re: Doweling Toe
« Reply #2 on: February 03, 2017, 07:11:12 AM »
You want to make sure the dowels aren't too big for the size of the toe. For example if the toe was 10 mm at the edge don't use a 9-10mm dowel. Always leave enough space is what I've found best so for the most part I use 6mm dowels
Re: Doweling Toe
« Reply #3 on: February 03, 2017, 09:43:30 AM »
Yes Toms right don't weaken the toe by drilling to big a diameter I did this  and it caused me more work.
Re: Doweling Toe
« Reply #4 on: February 03, 2017, 09:46:51 AM »
Have a look at jpgavans facebook page, he has dowelled many bats
Do I have to use the same amount of wood filler as him, or can I just use a dowel that fits the hole properly? ??? :-[
Churchy1989
Re: Doweling Toe
« Reply #5 on: February 03, 2017, 11:58:04 PM »
I did a diy job
WP_20161221_18_29_12_Pro by Matthew Church, on Flickr
Used bamboo cane as a dowel (5mm thick). Took a few Yorkers on 70/75mph on Monday, couldn't feel a weakness. unfortunately that bat is now in contention a match bat.......tooo many bats!
Re: Doweling Toe
« Reply #6 on: February 04, 2017, 02:31:19 PM »
The Goldilocks porridge approach applies here - not too small, not too big, needs to be just right!
langer17
Re: Doweling Toe
« Reply #7 on: February 05, 2017, 08:53:03 PM »
Cheers for the suggestion guys :)
As the doweling options were 6mm or 8mm, i went with 8mm as the toe/edge are rather thick so plenty of room either side of the hole. Will see how it goes
