This weeks helmets
Pages: 1 ... 22 23 [24] 25 26 ... 97
Author Topic: This weeks helmets  (Read 260589 times)
Re: This weeks helmets
« Reply #345 on: October 31, 2010, 12:45:39 PM »
yeah Dilshans £4 helmet didnt do him too much use in this incident....Same factory as Albion as well i believe ???
« Reply #346 on: October 31, 2010, 12:48:12 PM »
Theres a difference between conforming too and excelling in a test :D
Colesy
« Reply #347 on: October 31, 2010, 12:48:58 PM »
I normally fail them
Lekka Global Alliance
« Reply #348 on: October 31, 2010, 12:51:21 PM »
Is that the game he scored another hundred ?
« Reply #349 on: October 31, 2010, 12:55:41 PM »
No idea...he had a couple of stiches though
« Reply #350 on: October 31, 2010, 12:57:43 PM »
I bet he was happy with his hundred ! (not sure the price of this lid but I do hold the cert)
Colesy
« Reply #351 on: October 31, 2010, 01:02:33 PM »
I bet he wasn't about the helmet not protecting him 100 or no 100
johan95
  • Trade Count: (+105)
« Reply #352 on: October 31, 2010, 01:05:49 PM »
Isn't it the gap on the grille? You can change the adjustment no? (The gloves have definitely come off haha)
« Reply #353 on: October 31, 2010, 01:07:20 PM »
the gap between the peak and grill can be adjusted but the plastic peak will still flex and widen the gap when hit like that due to the materials being used to make the shell..
The gloves arent off..its just a discussion which the forum is all about and enlightening people as to how/why some products work and some are far less effective
« Reply #354 on: October 31, 2010, 01:08:55 PM »
I think Thomas maybe referring to a poor grill selection position by the batsman in the mentioned photo.
« Reply #355 on: October 31, 2010, 01:10:23 PM »
the gap can be set to the 55mm BSI specified but the peak will then flex when hit and the ball will go through it still due to the fact the plastic used to make them is the same as whats used to make washing up bowls from
johan95
« Reply #356 on: October 31, 2010, 01:11:25 PM »
Ok point taken. It seemed a bit heated earlier on, but I guess it was just banter! Yeah you're right Tom, the grill position isn't very clever.. :|
« Reply #357 on: October 31, 2010, 01:14:23 PM »
James and i are used to verbal jousting mate dont worry!
As stated above the grill position isnt clever but the structural rigidity of the helmet still would more than likely not keep the ball out....get a plastic helmet and try bending the peak and you'll see what im getting at
« Reply #358 on: October 31, 2010, 01:15:32 PM »
tbh , there appears to be a flaw in the standard where the grill is allowed to be positioned in 3 different settings. Albion as a market leader for some years have seen top players like Ponting being injured more than once.
johan95
« Reply #359 on: October 31, 2010, 01:16:55 PM »
tom, out of interest do your helmets only allow the grill to be positioned in one setting..?
