Author Topic: Interesting article about bat weights and sweet spots  (Read 5581 times)
adb club cricketer
« on: July 19, 2017, 05:10:28 AM »
Not sure how much of the info is accurate, but the article goes in depth about the weights and exact sweet spot locations of several Ind players' bats.
http://timesofindia.indiatimes.com/sports/cricket/ms-dhoni-may-have-to-change-bat-to-stay-within-rules/articleshow/59660160.cms
addu84
Re: Interesting article about bat weights and sweet spots
« Reply #1 on: July 19, 2017, 08:51:44 AM »
Those are extremely light bats (all sub 2.8lbs).
« Reply #2 on: July 19, 2017, 09:58:47 AM »
Article seems like rubbish - 12 inch sweet spot? Really? Kholi using 2.5? Come on.
springbok45
« Reply #3 on: July 19, 2017, 11:46:33 AM »
1160g is 2lb 8.9oz, the decimal of 2.55lb is two and a half.
« Reply #4 on: July 19, 2017, 12:10:52 PM »
2.5 pounds means '2 and a half pounds'
Half a pound is 8 ounces.
« Reply #5 on: July 19, 2017, 12:12:11 PM »
Ah my mistake - makes more sense now still firmly disagree on a 12 inch sweet spot though
« Reply #6 on: July 19, 2017, 12:26:32 PM »
Its pretty common and an easy mistake to make, and the biggest con going on ebay when people buy 2.6 or 2.7 bats expecting a feather and they end up with heavy clubs. Seller technically hasn't mislead anyone of course, but they know what they are doing. Always get a photo of the bat on a scale when buying from ebay or bedroom seller types.
« Reply #7 on: July 19, 2017, 12:31:15 PM »
This is a very good article! The weights are in grams and you need to convert to pounds and ounces to get accurate picture of their weight. Dhoni, for instance,  uses a bat between 2-11 to 2-12.8. If you've seen pictures of Kohli's bats, you will notice that there is a lot of meat behind the sweet spot. They also get the pingiest bats and anyone who's used "pro" bats will agree that they ping everywhere.
« Reply #8 on: July 19, 2017, 12:38:31 PM »
I have used a pro bat (in fact 2) yes it was very good but no it did not have a 12 inch sweet spot
adb club cricketer
« Reply #9 on: July 19, 2017, 03:38:18 PM »
Ya, seen so many buyers get conned when they hear 2.7 lbs. Even here on the forum, many people make that mistake: Remember 2.7 lbs is not 2 lbs 7 oz,  as simple as that. Best way as Vitas said is to see pic of bat on scales or ask weight in grams so you can calculate yourself:
Approximately, here are the values for common weights, every 30 grams adds 1 oz approximately, and easy to calculate for any weight if you remember just one entry like say 1160 grams = 2 lb 9 oz.
1100 grams = 2 lb 7 oz
1130 grams = 2 lb 8 oz
1190 grams = 2 lb 10 oz
1220 grams = 2 lb 11 oz
1250 grams = 2 lb 12 oz
