Pages: 1 [2] 3 4
Author Topic: Bat Design Idea  (Read 12607 times)
joymarvin
Re: Bat Design Idea
« Reply #15 on: July 20, 2017, 10:40:12 AM »
This is why I don't really favour "a design your own bat" approach by clubbies. As I believe it takes away the batmakers skill and judgement when shaping to some extent. You cant buy experience.
Anyone ever hit a six off the toe end of the bat?
Why would you want a 40mm toe,  in one of the deadest zones of a bat  ?
I agree.
shax12
Re: Bat Design Idea
« Reply #16 on: July 20, 2017, 11:25:43 AM »
Maybe some clubbies are only good at using the toe and not the middle so blame the toe for being too thin for their shortcomings.
Churchy1989
Re: Bat Design Idea
« Reply #17 on: July 20, 2017, 02:33:27 PM »
a very bad idea...
Re: Bat Design Idea
« Reply #18 on: July 20, 2017, 03:05:49 PM »
The toe sounds like the longer bladed mongoose.
Yep the Cor3 has pretty close to a 40mm toe, long middle, extended edges etc and is much nicer than this idea!
KW9221
Re: Bat Design Idea
« Reply #19 on: July 20, 2017, 03:15:42 PM »
Agreed! I have heard them quite a lot.
Instagram: Cricketer_guru
Tom
Re: Bat Design Idea
« Reply #20 on: July 20, 2017, 03:52:51 PM »
The theory behind the Mongoose was the following:
Bigger toes = higher MOI = greater batted ball speed for bat weight
I accept batmakers have lots of experience and that should be taken into account. That said, there isn't much scientific about shaving a block of wood in pretty much the same way they have done for 100 years. We should continue to challenge that with bat designs and innovation.
Re: Bat Design Idea
« Reply #21 on: July 20, 2017, 05:16:37 PM »
I'm a big fan of this line of thinking, not a theory unique to cricket bats either!
Re: Bat Design Idea
« Reply #22 on: July 20, 2017, 06:46:26 PM »
What is MOI?
Re: Bat Design Idea
« Reply #23 on: July 20, 2017, 06:57:40 PM »
Be a very boring world if we just accepted the bats given to us by batmakers though wouldn't it.
Enough plagiarism going on without becoming origin.
I like concept and design and hope people never stop tinkering even if it goes full circle
LBWCandidate
Re: Bat Design Idea
« Reply #24 on: July 20, 2017, 07:10:30 PM »
That pick up won't work for me. It will feel like 2.12 even if its 2.8ish I think.
Laverwood Ultra might be closer to this profile but not such a massive toe.
Re: Bat Design Idea
« Reply #25 on: July 20, 2017, 08:09:19 PM »
Moment of inertia. No strictly correct, but roughly "swing weight"/ pickup
Thanks.
Good article about "MOI": http://www.acs.psu.edu/drussell/bats/bat-moi-details.html
#MOI
#MomentOfInteria
#SwingWeight
jd163
Re: Bat Design Idea
« Reply #26 on: July 20, 2017, 08:41:01 PM »
IMO the craziest bat in existence with super low middle is Laver & Wood Legacy Ultra.
http://www.laverwood.co.nz/legacy_detail.php
Got wood!
Re: Bat Design Idea
« Reply #27 on: July 20, 2017, 09:22:36 PM »
I would love to give one of they a go
Get a part made bat off a forum sponsor, shouldn't take too long to copy that shape - you only have to do the top end after all!
Calzehbhoy
Re: Bat Design Idea
« Reply #28 on: July 21, 2017, 06:33:01 AM »
I used to use basically this. My mate had a puma that was an absolute cannon, he completely destroyed the toe beyond repair not wanting to throw away such a great bat (He was going to skip it) I cut off the bottom inch or two so the toe was now at the start of the middle.
We called it the PumeGoose and it absolutely flew!
Re: Bat Design Idea
« Reply #29 on: July 21, 2017, 07:34:15 AM »
Not sure it works quite as simply as cutting off the bit below the middle and the toe now being as 'pinky' as the previous middle was!
Pages: 1 [2] 3 4
