Pages: 1 2 [3] 4
Author Topic: Bat Design Idea  (Read 12606 times)
Bat Wizard
Re: Bat Design Idea
« Reply #30 on: July 21, 2017, 07:40:20 AM »
I don't have the software to craft this but lets see if anyone can capture my imagination.
Starting with the toe = 40 mm thick and solid
Going up from the toe towards the mid, the first 2 inches with no concaving or spine.
Edge size starts to diminish and becomes about ~35 mm in the middle with significant concaving in the profile with a spine about 55 mm
The sweet spot or the middle of the bat, very, very high to balance out the thick toe.
Spine remains at about ~ 25 mm where it meets the handle
Shoulders about ~ 20 mm
A very deep Asian style bow in the profile
Roundish Handle
And obviously not more than 2.8  in hard pressed grade 3 willow.
For you as asked....
Calzehbhoy
Re: Bat Design Idea
« Reply #31 on: July 21, 2017, 07:44:21 AM »
Geezus.....Is there any wood behind those stickers??
Bat Wizard
Re: Bat Design Idea
« Reply #32 on: July 21, 2017, 08:00:43 AM »
One of my friend got it made and shared this sometimes back .
skip1973
Re: Bat Design Idea
« Reply #33 on: July 21, 2017, 08:40:28 AM »
Internal trainings wet dream?
Re: Bat Design Idea
« Reply #34 on: July 21, 2017, 11:44:10 AM »
You seem to be obsessed with my "wet dreams". I think you need some serious psychological help.
Sitonit
Re: Bat Design Idea
« Reply #35 on: July 21, 2017, 08:50:02 PM »
Looks heavy but impressive.
I would like have significant convacing starting two inches above the toe, and slightly reduced edge size where it's the biggest. Sweet spot also needs to be moved up north to counter balance the fat toe.
By yes, your bat sure does look scary.
Sitonit
Re: Bat Design Idea
« Reply #36 on: July 21, 2017, 08:54:28 PM »
Maybe some clubbies are only good at using the toe and not the middle so blame the toe for being too thin for their shortcomings.
We have recently started playing cricket on asphalt pitches where spin bowling is not allowed.
There is no finding the middle of the bat. The ball pitches at regular length and appears in front of your nose.  If it's yorker, it breaks the bat so you need to have a fat toe, or else you must have a very high middle to take the pacey balls in front of your chest.
This cricket is not for the faint hearted. May be you wanna join us in a game or two?
Biggie Smalls
Re: Bat Design Idea
« Reply #37 on: July 22, 2017, 06:59:22 AM »
@InternalTraining .... dude , you missed a golden opportunity here . If you had just replied 'how much bow ? How thick is the toe?' you would have gotten 100 likes for that comment !   :D
Bat Wizard
Re: Bat Design Idea
« Reply #38 on: July 22, 2017, 07:15:54 AM »
This bat weighed 1100 grams. I would not call it a heavy bat.
Scary yes, my friend named it the ugly one.....
He is enjoying using it though....
Idea of concaving is only to get a desired weight, doesn't help
In anything else.
Number 11
Re: Bat Design Idea
« Reply #39 on: July 22, 2017, 03:13:14 PM »
Jeez, that sounds like a nightmare to play on.
Biggie Smalls
Re: Bat Design Idea
« Reply #40 on: July 22, 2017, 03:17:27 PM »
In anything else.
I would beg to differ .... two bats the same weight , profile - basically all other things being equal , i would usually find the one with a bit more concaving more balanced .
Bat Wizard
Re: Bat Design Idea
« Reply #41 on: July 22, 2017, 03:32:14 PM »
That's a Valid point, considering the dynamics of the bat.
You are right in saying what u say !!!
Sitonit
Re: Bat Design Idea
« Reply #42 on: July 22, 2017, 03:34:38 PM »
In anything else.
If it's 1100 grams then I would like to buy one as well. I thought it looked at least 3 lbs.
Can I get in touch with your friend to give his reference of this bat when placing an order with BDM?
Bat Wizard
Re: Bat Design Idea
« Reply #43 on: July 22, 2017, 03:39:16 PM »
I am not sure if my friend is on this forum.
Try aditya mahajan on Facebook.
sachin200
Re: Bat Design Idea
« Reply #44 on: July 22, 2017, 03:55:57 PM »
Something like this? Your exact dimensions, would actually come out around 2lb9 with a standard density bit of willow (allow for a bit of guesswork on how much a handle weighs).
Have you talked to Laver guys yet? They already have something called Legacy which is quite similar to what you want.
Pages: 1 2 [3] 4
