Hunts Clearance
Author Topic: Hunts Clearance  (Read 3410 times)
mohawks94
Hunts Clearance
« on: July 31, 2017, 02:31:08 PM »
Stumbled across Hunts having an online clear out on eBay. This is the link: http://www.ebay.co.uk/itm/152644509165
I bought myself one of these, a 2lb8 with 15 grains, so will be putting up a review once it arrives!
Gingerbusiness
Re: Hunts Clearance
« Reply #1 on: July 31, 2017, 03:17:31 PM »
I saw this mate. Grains look great and if its a TK one, it will perform great too but the shape looked a little odd to me so didn't buy it. I am sure it will be amazing though :)
Re: Hunts Clearance
« Reply #2 on: July 31, 2017, 05:14:56 PM »
er... TK Hunts?!
Re: Hunts Clearance
« Reply #3 on: July 31, 2017, 05:29:04 PM »
er... TK Hunts?!
Can't see the shape. Only the face.
Re: Hunts Clearance
« Reply #4 on: July 31, 2017, 05:47:23 PM »
£260? Clearance?
Churchy1989
Re: Hunts Clearance
« Reply #5 on: July 31, 2017, 08:47:45 PM »
£260? Clearance?
So you can get a Custom pro for around £245 and these are £15 higher, but I am assuming these are the shape of a pro players bat, and these clefts are held back for the pro's even though an amateur is looking to buy.
Cant beat them tho, go like freight trains!
Re: Hunts Clearance
« Reply #6 on: July 31, 2017, 08:59:37 PM »
Customs at £245 are G1+
These players grade are made from the low density wood wood I believe.
All that said I still think the £205 grade 1 custom is up there as one of the best value deals going! I've not seen or used a bad Hunts bat yet, so whatever grade you get it's likely to perform  :)
Churchy1989
Re: Hunts Clearance
« Reply #7 on: July 31, 2017, 09:11:06 PM »
Thought my G1+ was a pro from hunts, must have got it wrong. Went through Jake for a bat copy, perfect copy, is a gun!
mohawks94
Re: Hunts Clearance
« Reply #8 on: August 02, 2017, 04:27:37 PM »
My new beauty arrived today! Unfortunately I was at the gym when it arrived and faced a quiz on why I have bought another bat from my mother...
Specs:
Weight: 2lb8oz
Max edge size: 40mm
Max spine size: 63mm
Handle: Semi oval
Grains: 15/16
First impressions:
Light as a feather with a beautiful pick up. Tried bouncing a ball on it for a bit and the response is ridiculous. Only an ounce lighter than my B3, the spine on this starts marginally higher, middle in pretty much the same spot and much the same profile apart from this being very concaved - shape 19 by B3 is only slightly concaved. Comparison pics below.
I think I am going to have a lot of fun with this one!
« Last Edit: August 02, 2017, 04:31:35 PM by mohawks94 »
