Homemade Photo-booth
Author Topic: Homemade Photo-booth  (Read 10351 times)
    • Neon Cricket
« on: October 19, 2017, 03:03:17 PM »
Right, I've been fiddling for a while for a way of taking half respectable photos without spending the earth so wanted to share my idea with you all. Most companies opt for the standard "bat on top of a pile of willow shavings" look however I was after something a bit different which lead to my mini project. I should absolutely stress at the start that it's by no means perfect - DIY is not a strong point of mine!!
The plan is to start a thread of all the bats I send out, so once I've finished the current batch of photos I'll get that one started :)
Step 1.
I started off with 6 panels of 610mm x 1220mm hardboard, in hindsight I should've just gone for 3 panels of 1220 x 1220 but available funds meant opting for the cheaper option!
Step 2.
I bought 6 meter squared artificial grass mats and cut them down to size to fit the panels - again I should've bought a wider/longer roll of grass, but at 5 times the cost I'm still pretty happy with the outcome from the cheaper mats!
Step 3.
I was after something to raise up the booth, so naturally everyone's favourite Swedish furniture company came to the rescue in the form of 5 dirt cheap side tables - I've arranged them to give the boards the highest level of stability.
Step 4.
Just a case of putting it all together - not the perfect fit, but it'll do the job for what I'm after so cannot complain for the price I've spent (in total it's come to just under £100 inc an additional lamp which I'm yet to set up).
The outcome:
So these are the first couple of photos I've used the booth for - I still need to do a bit of editing on them, but overall I'm pleased with the output and its given me a good solid background.
The next step will be to get the lighting sorted, but thanks to Mr IKEA I should have that sorted shortly - will update accordingly!
« Last Edit: October 19, 2017, 03:05:18 PM by Neon Cricket »
mattw
    • PRYZM Cricket
Re: Homemade Photo-booth
« Reply #1 on: October 19, 2017, 03:10:01 PM »
Without going to Ikea, you can spend around £20 on some decent lighting for 'whitebox photography' on eBay.
    • Neon Cricket
« Reply #2 on: October 19, 2017, 03:19:32 PM »
Cheers Matt, I'll check it out!
Woodyspin
« Reply #3 on: October 19, 2017, 06:13:10 PM »
Some lovely LED lighting would sort that out
    • Neon Cricket
« Reply #4 on: October 19, 2017, 08:37:44 PM »
Will give it a look, I've got a daylight bulb with dimmer I'm going to fiddle with but will try some LEDs too!
Woodyspin
« Reply #5 on: October 19, 2017, 08:52:32 PM »
Amazon do some for less than £100 and one I've seen is 3 with 3 stands and a bag for £115. Depends on your budget i suppose
