Author Topic: Same Weight But Different Thickness Of The Bat  (Read 3938 times)
Re: Same Weight But Different Thickness Of The Bat
« Reply #15 on: October 20, 2017, 09:57:54 PM »
Bat speed has a fair amount to do with it.  And to be fair timing. A heavy bat is only useful in the hands of someone with the strength/timing to wield it.
« Last Edit: October 20, 2017, 10:01:43 PM by Gurujames »
« Reply #16 on: October 20, 2017, 11:08:09 PM »
This is true. There is an optimum middle between weight and bat speed for each individual where they can hit sixes with the max possible weighted bat they can wield and swing to produce a certain bat speed. In a coaching video that I saw, the coach said that you need 80+ mph bat speed to hit the ball 90 yards.
https://www.youtube.com/watch?v=kIrThkyIGYs
jd163
« Reply #17 on: October 21, 2017, 12:38:26 AM »
From the experience with the bats i have i can confirm that Bigger size bats pings & perform better than the smaller size bats of same weight.
I have 5 bats with same 2-13 weight and but different sizes. Here are the rating performance wise
GN Signature (51 edge and 75 spine)
B3 Warner Replica (50 edge and 70 spine)
Kook Obscene (48 edge and 70 spine)
Aldred Velocity (35 edge and 60 spine)
B3 TKC (43 edge and 65 spine)
Hope this helps.
Got wood!
Woodyspin
« Reply #18 on: October 21, 2017, 12:41:35 AM »
All in your head
Churchy1989
« Reply #19 on: October 21, 2017, 11:44:39 AM »
I may be wrong (I normally am), but I recall seeing a post or something on the internet. Its was to do with the height of the spine, and were the ball is struck, to optimise the response of a shot it should be in the middle and struck at the highest point of the spine. This was to do with the vibration from where the ball strikes the bat which goes to the back of the bat (spine) and then back to the face.
Without finding the thread or site I have no prof and I am by no means a scientist. I don't think it is the density of the bat but the volume of wood from the face to the spine.
You can then go into pressing - but I do not know much about that.
« Reply #20 on: October 21, 2017, 03:15:15 PM »
This is a good point. What you are describing is the same principle behind a golf driver.
