Same Weight But Different Thickness Of The Bat
Author Topic: Same Weight But Different Thickness Of The Bat  (Read 3923 times)
« on: October 20, 2017, 02:24:57 PM »
How does it affect the rebound? If the cleft is low-density and a bat weight 2-10, one bat is thinner (old fashioned) and the other is a lot thicker, does this affect how the ball rebounds? Is energy transfer or vibration of the thicker bat (albeit low density) greater than the thinner bat? I don't think F=MA fully explains the characteristic of the rebound since the low-density bat has a larger surface area, more air-pockets in the willow for compression/decompression, and overall more flexibility in the wood to create the whippy affect. It is like a trampoline and wooden board (of same weight) but trampoline generates a lot higher bounce.
Thoughts?
Experiences?
Re: Same Weight But Different Thickness Of The Bat
« Reply #1 on: October 20, 2017, 02:30:50 PM »
In my experience thicker bats/lower density clefts do not rebound better than more traditional shapes. The difference i have found is when I edge it it goes further.
alexhilly1492
« Reply #2 on: October 20, 2017, 02:43:11 PM »
I have two bats same weight one is a lot smaller than the other but is a better bat
Different makers granted,
The only way tk Test this would be to have one bat maker make two bats same weight different density in the same day with the same tools etc then have an hour on a Boeing machine etc
BB: 7-4-9-5, 7.3-0-29-5
« Reply #3 on: October 20, 2017, 02:43:48 PM »
Surface area?! Nothing to do with it. Air pockets - errr, no? More flexibility - quite the opposite, a thicker cross-sectional area will be more resistant to bending, ie. stiffer. Stiffer means less energy lost in deformation = more energy transferred to the ball = ball goes further. For the differences you're talking in cricket bats though, this isn't going to make a big difference.
CrickFreak
« Reply #4 on: October 20, 2017, 02:44:05 PM »
^^ I agree. Thicker edges will make a difference as they will minimize bat rotation.
To your comparison of trampoline and wooden plank - they are made of completely different materials.
The "air pockets" reference makes sense but the dry bat fibers are quite rigid to have large compression and de-compression to get the trampoline effect.
In my opinion, ball hit from the middle of two bats of equal wieght should travel same distance assuming they pressed the same etc etc
« Last Edit: October 20, 2017, 02:46:04 PM by CrickFreak »
« Reply #5 on: October 20, 2017, 02:53:09 PM »
Isn't that the theory behind the GN scooped bats? Are those bats really rockets? Lot of people like them.
CrickFreak
« Reply #6 on: October 20, 2017, 03:06:36 PM »
I meant for off center shots, thicker edges might have an advantage..... Never used scoop and not sure i will like it either :)
sachin200
« Reply #7 on: October 20, 2017, 03:10:18 PM »
I don’t agree with the thicker edges prevent twisting theory since if you have same amount of wood in both bats on their edges, both bats should respond the same way for twist. Further, the twist can be reduced by simply having a pronounced oval handle. Air pockets in the bats don’t matter either but what matters the most is what is the characters of the 1 cm face thick face of a bat. Does it have enough rebound in it caused by moderate pressing? If pressed too hard (or knocked using a metal hammer), that bounce/ rebound reduces leading to poor performance. In my opinion, thicker bats only provide psychological advantage and that’s all!
« Reply #8 on: October 20, 2017, 03:18:12 PM »
Distribution of more mass around the edges improves the response to an off-centre impact, which is the (well-proven) theory behind the Scoop. Just bigger edges won't necessarily have the same effect, and certainly not to anywhere near the same extent. Handle shape doesn't make a blind bit of difference, the ball has already left the bat by the time your hands get involved.
« Reply #9 on: October 20, 2017, 03:32:22 PM »
You mean 1cm from the surface of the face to the bat down towards the core?
sachin200
« Reply #10 on: October 20, 2017, 03:50:16 PM »
Yes. i mean 1 cm towards the core of the bat.
I also believe that if thick edge (pressed lightly) and thin edge (pressed heavily with a curved faced roller) should perform the same as long as the amount of wood on the edges is same in both cases.
Canners
  • go hard or go home
« Reply #11 on: October 20, 2017, 04:06:39 PM »
where is andy @safbats when you need him :)
« Reply #12 on: October 20, 2017, 04:43:10 PM »
Playing with his monkey?
« Reply #13 on: October 20, 2017, 07:23:23 PM »
Is that a euphemism? ???
adb club cricketer
« Reply #14 on: October 20, 2017, 09:26:24 PM »
According to new ICC regulations, a batsman is allowed to use a 3 lb, 40 edge monster but can't use a 2-8, 41 edge bat. And this is to restore the balance in favor of the bowler! So at least what the ICC thinks on this matter is pretty clear!
« Last Edit: October 20, 2017, 11:28:17 PM by adb club cricketer »
