Pages: 1 ... 9 10 [11] 12
Author Topic: Beach's Bat Making  (Read 35146 times)
Re: Beach's Bat Making
« Reply #150 on: April 19, 2012, 04:04:55 PM »
Beachy a question for you mate;
Since hand finishing is a lot more time consuming, energy consuming and what not! Why don't you take option of power sander, finish majority of the bat and then give final coat with hand ensuring finishing is as good as you current work. Surely that means less work, no ?
Looking forward hearing your response.
Beachy's finishing is fanstastic, recieved a bat yesterday from him and was pleasantly surprised with how well it is finished, am also very impressed with the balance and shape of the bat.
No pictures = no bat
Simples :D
« Reply #151 on: April 19, 2012, 04:18:57 PM »
Simples :D
They are already here, second last post from Beachy is my bat :), I will take somemore tonight and post them..
http://custombats.co.uk/cbforum/index.php?topic=4335.msg276026#msg276026
or here
http://wieldingwhitewillow.blogspot.ca/2012/04/traditional-touch.html
« Last Edit: April 19, 2012, 04:20:32 PM by tusharsehgal »
Beachcricket
« Reply #152 on: April 19, 2012, 04:33:37 PM »
I think for the number of bats I'm making, buying a specific piece of equipment to do the sanding would be a waste of money. If I was going to buy anything it would be a pneumatic drum sander, but they're pricey. The sanding that I do by hand that compares to that done by a power sander is over pretty quickly. The finishing only takes me a long time because I get really fussy about it. I try to get it as good as I can.
If you can suggest alternative power sanding equipment I'd welcome it, if there is a quicker way that will yield similar or superior results I'll happily use it.
Beachcricket
« Reply #153 on: April 19, 2012, 04:40:47 PM »
It's the same with a buffing machine, I'd love to have one. However I don't have the money to spend on a piece of equipment I don't know how to use efficiently.
I could buy a bandsaw, disc/belt sander or planer/thicknesser and get good use from it because I have projects that would use that piece of equipment regularly.
Beachcricket
« Reply #154 on: April 26, 2012, 11:02:02 AM »
I've finished a new bat, weighing 2.14lbs. This one will be up for sale, perhaps going to ebay as it seems the heavier bats don't sell very well on here.
I won't add the whole blog post as there's 26 photos, and formatting back and forth would take forever.
http://wieldingwhitewillow.blogspot.co.uk/2012/04/special-bond.html
Hit Out or Get Out
« Reply #155 on: April 26, 2012, 11:22:52 AM »
Wow! Every time I read your blog i'm blown away by the quality of your workmanship, Keep up the good work. What do you use for finishing BTW?
Beachcricket
« Reply #156 on: April 26, 2012, 11:34:19 AM »
Apart from sandpaper, sometimes I use wax but I keep trying different brands but I'm not that keen on the finish I get yet.
« Reply #157 on: April 26, 2012, 12:55:21 PM »
Beachy, Hope you approve  :D
Beachcricket
« Reply #158 on: April 26, 2012, 03:18:49 PM »
Looks good, so long as it performs well for you I'm happy.
Beachcricket
« Reply #159 on: May 16, 2012, 07:35:27 PM »
What a difference a few ounces makes. You may remember I made a bat using a heavy cleft (or the heaviest cleft I had at 3lbs 13oz) and that whilst shaping that cleft a few truths became apparent to this novice bat maker. Making a bat with a lighter cleft isn't necessarily easier, it's just that you don't have to make half as many sacrifices along the way. With that heavy cleft I had to completely forgo the possibility of making a BIG bat, it had to subtle and sedate. A lighter cleft gives you so many more options.
I picked the lightest cleft I had for this bat which was 3lbs 7.4oz. I'm not sure if this is a light cleft in the grand scheme of willow or how light they can go but for me it's certainly the lightest I've ever had the fortune of shaping. Just to give you an idea of how versatile a lighter cleft is I decided to leave part of the spine as high as it arrived until finishing. I didn't go crazy with concaving and the edges are only 23mm at their thickest, it's all spine.
I'd been asked if I could make a bat in the region of 2lbs 7oz but this one should be 2lbs 9.5oz gripped and bound. One important lesson I have learnt is being able to realise when enough is enough. When the naked weight got to 2lbs 7.5oz, I figured I should stop before I ruined it. Having said that, I did have to change the edges from their original profile. I slipped with my round bottom plane and took a generous slice of willow from the edge by accident. It was easily fix though.
I'm trying to shape the toe of the bat with a bit more of a concave profile, just for something different.
This rough bit is the rough cut spine, I used this little slither to illustrate how I left the spine as high as I could.
There's that rough slither in the middle again, lots of spine and the weight was coming off with ease, I love light clefts.
The slither was a little bit narrower once I'd refined the back, but still there.
Edges have gone down and the swell moved upwards, huge improvement on the balance of the bat.
As finishing begins it starts to disappear. Goodbye old friend...
Not a face for the "blemish free/straight grain" crowd. But once you burnish the face and edges these marks look beautiful.
Remind me to focus my camera before taking photos, Tisk tisk!
Small edges, big spine and only approximately 2lbs 9.5oz. The spine has to be around 60mm or more, it's larger than an 3lbs bat I have.
These are great, the wood twists and turns. A nightmare to finish sometimes though.
As enjoyable as it was to make a bat with a lighter cleft, I have to admit a heavy cleft present more challenges and as a result you feel like you're learning more. Don't get me wrong, I'd happily use lighter clefts all the time but there are certainly issues that you'd never come across with a cleft at this weight or lighter. You can ask yourself "How much more do I want to take off?" rather than "How much more do I have to take off?". I'm not sure about you but I know which one I'd rather ask myself.
« Last Edit: May 17, 2012, 09:28:24 AM by Beachcricket »
Beachcricket
« Reply #160 on: May 17, 2012, 09:29:09 AM »
Finally got it formatted.
« Reply #161 on: May 17, 2012, 10:23:46 AM »
Marvellous, loving your work.
I am interested in your love of the concave toe, I can see you making a reflex shape before long! Personally I am going through a phase of liking a convex toe shape (which means a lower middle) - and would love to see you try and make one like that...
I think the user of this bat will be absolutely delighted with it.
pie-man
« Reply #162 on: May 17, 2012, 10:42:22 AM »
These bats are beasts!  Im a 2.12 + man - loving your work!
deanoknight
« Reply #163 on: May 17, 2012, 10:48:48 AM »
is this for sale?
Beachcricket
« Reply #164 on: May 17, 2012, 11:35:40 AM »
Thanks, I tend to make a convex toe and then flatten it out at the end. I've tried going the other way to see how it changes the way I shape the rest of the bat. I should do a really convex toe next time.
Deano - This bat is for sale.
