Severe delamination in oiled and knocked-in new bats
Author Topic: Severe delamination in oiled and knocked-in new bats  (Read 3279 times)
amnitg
« on: January 19, 2018, 12:38:10 PM »
Greetings from germany fellow cricket lovers and cricketers.
I've owned over 20 bats and was wondering if applying the recommended 3-4 coats
of raw linseed oil (learned this from a Julian Millichamp bat prepration video on youtube) before knocking it in is actually detrimental to the blade.
In my experience, my oiled and knocked in SF Sapphire, SS TON Professional and a BAS custom all started delaminating (i'm talking severe delamination here with those horrible hollow sounds and next to no ping off of the delaminated area) in the nets itself. Looking forward
to being enlightened :)
« Last Edit: January 19, 2018, 12:40:58 PM by amnitg »
amritpremi
Re: Severe delamination in oiled and knocked-in new bats
« Reply #1 on: January 19, 2018, 12:48:44 PM »
Check the balls being used in nets, maybe cheap rock types. Some pics will help guys in here diagnose the issue.
amnitg
« Reply #2 on: January 19, 2018, 12:56:08 PM »
Hi. thanks for the quick reply. all balls used in the nets are either old SG CLUB or Tournament balls. i'm not looking for a repair solution for delamination here. I just want
to know if there is a direct relationship between oiling and early delamination.
The Doctor
« Reply #3 on: January 19, 2018, 12:58:08 PM »
Shouldn't be any correlation between oil and de-lamination.
dbacon1980@gmail.com
Never stand still
« Reply #4 on: January 19, 2018, 01:11:11 PM »
No chance
Oiling a bat is not gonna cause delam issues
It’s either cheap rock hard balls,(cut one open) or the bats drying excessively
amnitg
« Reply #5 on: January 19, 2018, 01:16:28 PM »
No chance
was just going through this on the laver and wood website ( Topic link: https://laverwood.com/laver-woods-cricket-bat-lore-ch-28-why-bats-break-how-to-protect-them/ )
they wrote:
"Dry willow can be dealt with through oiling the bat, although be careful with how much you oil your bat as over oiling can damage the bat. Excessive oil may cause the fibres in the face of the bat to separate and therefore delaminate, making the bat vulnerable to splitting."
so, it very welll could be "over-oiling" that causes the early onset of delamination
Calzehbhoy
« Reply #6 on: January 19, 2018, 01:25:02 PM »
Over oiling is something that is very, very difficult to do! You'd more or less have to sit the bat in a bucket of oil for at least a few days to Over-oil a bat.
You applying 3/4 coats of oil to a bat isn't causing your problem.
« Reply #7 on: January 19, 2018, 01:38:53 PM »
we oil to seal in the exsisting bat moisture content over oiling can soften bat fibres
amnitg
« Reply #8 on: January 19, 2018, 01:56:24 PM »
So, over-oiling can soften bat fibres. Could this lead to delamination as well ?
« Reply #9 on: January 19, 2018, 02:24:23 PM »
 Yes softening  the bat fibres by over oiling makes the fibres  subsceptible  to splitting  which  can lead to delamination.
« Last Edit: January 19, 2018, 02:29:04 PM by Seniorplayer »
Blank Bats
    • Blank Bats
« Reply #10 on: January 19, 2018, 02:30:42 PM »
Inconsistency of pressing over the face area may be a possible cause.
Blank Bats
http://www.blankbats.co.uk
« Reply #11 on: January 19, 2018, 02:31:16 PM »
I would suggest you follow what the Dr says.
As mentioned above this would take litres of oil, not 3 or 4 goes.
If the bat is delaminated take it back to where is came from.
« Reply #12 on: January 19, 2018, 02:40:31 PM »
Agree it takes some doing but over oil can  clog deaden fibres
amnitg
« Reply #13 on: January 19, 2018, 06:13:11 PM »
Am grateful for all your responses.
staying on topic, does a hard-pressed bat delaminate quicker than a softer one?
« Reply #14 on: January 19, 2018, 09:09:50 PM »
No the softer the pressing the sooner the delamination begins
