That surprise when you put a bat on a scale...
Author Topic: That surprise when you put a bat on a scale...  (Read 5185 times)
« on: March 12, 2018, 02:50:58 PM »
Got a teammates' bat at mine atm to put a scuff on it for them, decent enough stick. Giving it a wave about and a little tap up I think this isn't half bad, picks up a bit light but I like the shape. Pop it on the scales to see what it is and well... The pictures should speak for themselves:
Looks alright for a low grade bat, nice shape and minimal concaving
Pretty sizable edges, spine is about 63mm measuring as best I can
On the scales she goes...
Madness! Imagine the monster this cleft could have made at 2lb11...
Re: That surprise when you put a bat on a scale...
« Reply #1 on: March 12, 2018, 03:24:37 PM »
And that’s with a scuff on too!
« Reply #2 on: March 12, 2018, 04:20:14 PM »
Is that a problem with mass market brands? Bats, particularly lower grade, are shaped and pressed as a 'one size fits all' without much attention paid to those clefts that are 'special' in ways other than their appearance.
play-yourself-in
« Reply #3 on: March 12, 2018, 04:41:27 PM »
I always thought I liked light bats, as I am painfully weak, I have never weighed a bat or specified a weight when buying one I just pick it up and wave it around. I was swinging a couple of bats around at home the other day, one feels super light and the other feels perfect for me. I assumed the super light was 2.6 and the other 2.7/2.8 I put them on the scales and the light one was 2.8 the other perfect weight on 2.9
Seems weight,  like age, is just a number!
« Reply #4 on: March 12, 2018, 06:47:25 PM »
Is that not measuring more like 54cm?  Still nice for The weight regardless. I did have a heavy wknd  tho so could be  seeing that wrong!  :( I like the look of some of the Kooks in the lower grades, there seems to be some nice lookers for grade 2/3s. The Surge is a lovely profile too.
« Reply #5 on: March 12, 2018, 06:54:45 PM »
Angle of the photo bud, I did put more effort into getting an accurate read of the spine than that! As you can tell from the wider shot, the spine is definitely more than 16/17mm bigger than the edge! 54cm would be enooormous mind ;)
@play-yourself-in 2.8/2.9 is definitely light!
Think that's probably a good point, a brand like Kook has more interest in turning the bats out cheap and quick than it does in searching out those special clefts. Not the worst thing in the world for the savvy consumer though as you can seek out super light sticks like this or pick up a bargain, especially with the new laws meaning this cleft couldn't be used to make a mega size bat.
Churchy1989
« Reply #6 on: March 12, 2018, 07:09:25 PM »
@edge does it have an A stamp on the shoulder?
Just done a refurb on a mates Aussie Kook. 40mm edge, 62mm spine with new stickers scuff and grip it's at 2.6lbs 😱.
« Reply #7 on: March 12, 2018, 07:38:36 PM »
2.6??
Gotta find a way of drying our wood out
« Reply #8 on: March 12, 2018, 08:41:58 PM »
Mark - used number 2 bat at nets for a couple of bags of balls!
Everyone that picks it up and waves it around think it weighs 2'10-2'12! Nobody has thought it weighed any more and most say around 2'10/2'11.
I put it on the scales and 2'14.5  :o
There are bats out there then genuinely feel lighter than they are and it's nice to find them!  :)
« Reply #9 on: March 12, 2018, 08:50:41 PM »
How much value you get for your shots with these light bats? If you are playing on lighting fast outfields, sure they will be fine. Anywhere else, duds!
« Reply #10 on: March 12, 2018, 08:55:22 PM »
Not true for me. I used a 2.6lb SS Turbo for many years.
Timing can make up for the benefit of weight/mass, also I found I generated a much faster bat speed.
These days I use a wide range of bat weights and don't find much difference between them.
« Reply #11 on: March 12, 2018, 09:03:57 PM »
Ah cheers Pete
I’ve got a couple more bats finished now, not quite as unique as that one, but hopefully the pick up/balance are as good
And I will figure out,how to upload pics and start a thread with my batmaking efforts
Also, with the making my own tools pics and vids to upload
« Last Edit: March 12, 2018, 09:05:42 PM by Northern monkey »
« Reply #12 on: March 12, 2018, 09:29:35 PM »
 :D Ha ha, 54cm would be some chunk of willow.....as I said, heavy weekend!
« Reply #13 on: March 12, 2018, 10:26:41 PM »
You must be a very good timer of the ball. I can never get any value with light bats. Maybe, I didn't use good light weight bats.
I wonder what's the weight of Rohit Sharma's bats? He is probably the best timer of ball of his generation.
prim0pyr0
« Reply #14 on: March 12, 2018, 11:00:51 PM »
Bats that feel lighter than scale weight = heavy handle?
