Author Topic: minor spine reduction  (Read 1954 times)
« on: March 23, 2018, 06:21:17 PM »
one of my bats is JUST slightly "illegal" - when going through the bat gauge, the spine makes the bat get stuck in the gauge. I think the difference is about 1-2mm in spine height, with the "extra height" running for about 8mm along the spine.
so to make it pass through the gauge, i would need to lower the spine height by 1-2mm (probably just 1mm) in a small section (8mm long) of the spine. can this be be done by just gently hand-sanding that area? I figured by going slow and gently, with fine sandpaper, i should be able to maintain most (obviously not all) of the "sharpness" of the spine?
Re: minor spine reduction
« Reply #1 on: March 23, 2018, 06:52:45 PM »
1 to 2mm, take you two minutes with some sandpaper
JK Lewis
« Reply #2 on: March 23, 2018, 07:25:32 PM »
Working through a few grades should do the job perfectly - maybe 120 / 180 / 240 / 320 - as fine as you prefer to go.
Having said that, the regulations for spine height are not actually in force for club players, and for existing bats will probably never be. You could just leave it as it is.
« Reply #3 on: March 23, 2018, 07:43:16 PM »
Oh for God's sake man! Just smack it against a door frame!
« Reply #4 on: March 23, 2018, 08:47:35 PM »
Give the raised area a gentle tap with your wooden knocking in mallet
Mattsky
« Reply #5 on: March 23, 2018, 09:21:15 PM »
Unless you're playing at County level, why bother?
Peter O' Toole
