Bat's cracked through the splice/spine
Author Topic: Bat's cracked through the splice/spine  (Read 2362 times)
« on: July 30, 2018, 08:03:52 AM »
Is there anything can be done in these cases, or it it jus ta case of keep using it until one day it goes pop?
Not my bat but similar break:
Re: Bat's cracked through the splice/spine
« Reply #1 on: July 30, 2018, 08:11:31 AM »
How deep towards the blade is the crack usually when they go there the bats had it/ not worth repairing.
Biggie Smalls
« Reply #2 on: July 30, 2018, 08:16:05 AM »
Looks like an e41/oblivion ....hope she makes it . One of my fave bats ever .
« Reply #3 on: July 30, 2018, 08:21:24 AM »
Not as deep as the one in the photo, maybe 10-15mm. Will try and snap a photo tonight.
« Reply #4 on: July 30, 2018, 12:50:17 PM »
Keep using until it breaks mate not worth the money or time even trying when they go like that
« Reply #5 on: July 30, 2018, 12:57:32 PM »
I figured as much, anything can be done to slow it's demise though?
« Reply #6 on: July 30, 2018, 04:52:06 PM »
In my experience no, glue won’t hold as the vibration will be too much, possible tightly bound edge tape off the role all around may give some support but that’s the best bet I reckon, basically start enjoying the process of buying a new bat
« Reply #7 on: July 30, 2018, 05:03:09 PM »
I repaired one that had gone there with glue in the crack clamped followed by more glue  all around the outside of the damage and bind on the outside with thick string stuck onto the glue threaded through a slip knot  loop to pull the string tight.
But it wasn't that successful.
Ajdal
« Reply #8 on: July 30, 2018, 07:49:10 PM »
Had something similar done to my XXX. Didn’t think it’d hold up but it has, I have scored roughly 700-800 runs since the repair. Slight bit of vibration in the top half of the bat but to be fair there was some vibration there even before the Bat broke( possibly due to it being flat face/less wood in the top half/lack of binding in the handle or all of these reasons I’m not sure)
