Practicing Bat Making
Author Topic: Practicing Bat Making  (Read 4769 times)
cornishchris
« on: August 16, 2018, 05:59:33 PM »
I've made a couple of part mades and they have come out ok, but mostly with having to finish off with a sander!
I was thinking of going to to the local wood yard and getting some bat sized pieces of pine and practicing on them as a bit cheaper!
Just wondering if anyone else had done this?
Cheers Chris
Re: Practicing Bat Making
« Reply #1 on: August 16, 2018, 07:21:43 PM »
Really good idea, pine is cheap and soft so you can practice. It is a very good way to learn.
« Reply #2 on: August 16, 2018, 07:48:53 PM »
You could try your council  local tip they usually have plenty of wood all types  for free as they only set fire to it.
« Last Edit: August 16, 2018, 07:50:33 PM by Seniorplayer »
cornishchris
« Reply #3 on: August 17, 2018, 06:17:21 AM »
Thanks gents, will get a few pieces, it's just getting used to the tools. I'm definitely getting better but easier to just go for it on a bit of pine, particularly with a draw knife as once you've taken it off that's it!
« Reply #4 on: August 17, 2018, 07:44:34 AM »
I found the drawknife relatively easy to use, but I shape my bats sat down
If you YouTube shave horses, you can see how the Americans use the drawknife
I find I’m a lot steadier, using it this way, and can remove material a lot easier.
I also use a travisher a lot,,probably too much, but I reckon I could shape a bat just using it,,it’s that versatile.
It’s surprising how little you need to make a bat
cornishchris
« Reply #5 on: August 17, 2018, 07:47:28 AM »
One day I'll invest in a travisher look a really good bit of kit.
Will have a look at those clips
« Reply #6 on: August 17, 2018, 07:56:10 AM »
I reckon a bat made from Mahogany would be pretty cool.
Something @Buzz would've used, back in his days in the Raj!
cornishchris
« Reply #7 on: August 17, 2018, 08:07:12 AM »
Could give it a nice french polish!
« Reply #8 on: August 17, 2018, 01:11:22 PM »
....and the bat - ahahahahahahah!!!!
SAFC2403
« Reply #9 on: September 25, 2018, 10:07:01 AM »
As i'm a complete novice at this i've been thinking this is the way to go - grab some random bits of wood and see what shape i can get them into - mainly to get used to using the tools and i dont want to screw up a part made!!
Churchy1989
« Reply #10 on: September 25, 2018, 11:13:56 AM »
Its pretty easy if the tools are sharp. Just take your time on some Partmades - contact a bat maker and ask for some damaged ones on the cheap. they will have some laying around.
SAFC2403
« Reply #11 on: September 25, 2018, 12:30:28 PM »
Never thought of that - i'll ask the guy i'm getting them off if he has any laying about. Just itching to get started now but need to wait for kit to arrive etc.
stevat
« Reply #12 on: September 25, 2018, 02:43:08 PM »
Who are you getting them off if you don't mind me asking?  Can PM if that would be better.  Thinking of having a crack at this in the not too distant future.  May even have a blast at putting together a press, got a few things in mind which could work, but which equally could be hair-brained lunacy.
SAFC2403
« Reply #13 on: September 25, 2018, 02:44:42 PM »
One of the forum guys red ink cricket - I've also emailed paul aldred as I bought my last bat from him.
Be interested in your press ideas - its something i may be looking at a little further down the line!!
« Reply #14 on: September 25, 2018, 02:46:38 PM »
Or work on some old bats? Take a bit of weight off or re balance, re profile them
Plenty of sh%te on eBay
Forgot to say,,I use an electric plane,,,I’m useless with a hand one
