variation on a middling bat.
Author Topic: variation on a middling bat.  (Read 1577 times)
blindowl
« on: February 21, 2019, 01:51:19 PM »
not personally seen one like this before.
Looks a bit gimmicky and poorly crafted but perhaps an interesting variation on the 'middling' bat.
https://www.ebay.co.uk/itm/Sweet-Spot-Training-Cricket-Bat/323624315230?hash=item4b5983295e:g:um8AAOSwo1lcJMkM:rk:2:pf:1&frcectupt=true
Psi
Re: variation on a middling bat.
« Reply #1 on: February 21, 2019, 02:03:41 PM »
Cool! That would certainly cause some raised eyebrows at the nets...
« Reply #2 on: February 21, 2019, 02:26:06 PM »
Could also see those sharp corners coming off quite soon too. Not for me.
« Reply #3 on: February 21, 2019, 02:32:51 PM »
What’s the benifit over a middling bat, the idea that a thick edge near the middle is better than one not near the middle?
blindowl
« Reply #4 on: February 21, 2019, 02:50:42 PM »
not sure there 'is' any benefit really Kulli.
However - Might be that you can 'play defensive' with the middling bit but be a bit more expansive with the extended area if it is in your attacking arc.
Do people practice powerful drives cuts etc with a middling bat?  I've always assumed they were for getting your eye in in a fairly defensive/controlled way.
« Reply #5 on: February 21, 2019, 03:35:42 PM »
:D
Why not attach a square piece of wood to a lacrosse stick that'd make it so much more challenging.
Just use the regular bat for practice, use soft balls (Bola JR balls are great) to improve your timing. I am not a fan of practice bats.
