PremAYR Steel and Titanium
Author Topic: PremAYR Steel and Titanium  (Read 9023 times)
« on: March 20, 2019, 07:43:38 AM »
If your looking for a helmet that offers a truly bespoke fit and protection to the highest level then look no further...
You can use voucher code CBF10 at the checkout to save 10% off of the RRP on all helmets.
Any questions please shout.
avkrish
Re: PremAYR Steel and Titanium
« Reply #1 on: March 20, 2019, 08:39:53 AM »
Hi Tom @Ayrtek Cricket, is D30 lining available for your traditional style helmets?
« Reply #2 on: March 20, 2019, 08:41:38 AM »
When you say conventional do u mean the TradAYR model? Is so then yes it can be retro-fitted by swapping them over 👍
avkrish
« Reply #3 on: March 20, 2019, 08:50:50 AM »
@Ayrtek Cricket, yes it is. Sent you an email a few minutes back. Please respond when you get time.
« Reply #4 on: March 20, 2019, 08:52:51 AM »
Thanks, for clarity the D3O liners can be retro fitted into any of the air liner helmets in the range as they all use the same shaped liner/foam pieces.
Mattsky
« Reply #5 on: March 20, 2019, 08:27:46 PM »
Tom, do you have any plans to manufacture helmets of different sizes?
Although the inflatable lining is adjustable to fit head size (which works very well), the two helmets I've had in the past looked huge on my relatively small noggin.
Even though they fitted well.
Peter O' Toole
« Reply #6 on: March 20, 2019, 08:36:41 PM »
Hi Matt.
The issue with different sized shell is the associated costs as each shell would require new tooling, this in turn would mean new liner tooling and quite possible new grille tooling too.
As I’m sure you can imagine tools aren’t that cheap to produce which was why I’ve operated on the one shells size and different liners model up until now.
It’s something that is doable but At a considerable cost.
