Best Glue
Author Topic: Best Glue  (Read 2888 times)
Best Glue
« on: July 05, 2019, 07:23:21 PM »
For all the bat makers on here please can I ask what glue do you use for glueing the splice in and also any of the more major repairs etc you carry out?
Thanks
Psi
Re: Best Glue
« Reply #1 on: July 06, 2019, 12:11:35 AM »
Various wood glues tried and all work fine if properly clamped. I wanted to find the glue that Fantail cricket use in their repair videos on Youtube. It is clear and slightly brown coloured. I think it might be Gorilla Glue. Has anyone else tried this? It seems to have worked well on a few major repairs I did recently. You have to clamp the repair and then the glue expands, with any excess drying as a yellow foam. Didn't leave such an unsightly dark line along the repaired crack, which is good, but quite difficult to remove the excess.
Psi
Re: Best Glue
« Reply #2 on: July 06, 2019, 12:12:14 AM »
... I'm not a bat maker though, just an amateur repairer...
Andythomo21
Re: Best Glue
« Reply #3 on: July 06, 2019, 08:30:50 AM »
Same hear, just do amateur repairs not a bat Maker!  I’ve seen cheap PVA in a few batmakers workshops and on videos so it must do the job.  Just for piece of mind I pay a little bit more for Gorilla Glue PVA and had no issues.👍
Cholrudee
Re: Best Glue
« Reply #4 on: July 07, 2019, 01:14:17 AM »
skip1973
Re: Best Glue
« Reply #5 on: July 07, 2019, 07:00:21 AM »
Only works on Lekka bats.
Re: Best Glue
« Reply #6 on: July 07, 2019, 10:37:56 AM »
Cheers all, so it seems from a couple of reply’s and from a few bat makers Gorilla glue is the best option so I’ll give that a go as it’s a rather special bat I want to repair and get some use from.
Psi
Re: Best Glue
« Reply #7 on: July 07, 2019, 12:04:01 PM »
Did they recommend Gorilla Glue, or Gorilla Wood Glue? The first is the one I have been using recently...
    • Neon Cricket
Re: Best Glue
« Reply #8 on: July 07, 2019, 05:25:58 PM »
I've used both gorilla glue and PVA and have found little difference between the two to be honest - I've been using a decent PVA for the past few months and it does the job for any repairs/refurb jobs I've had to do
Canners
  • go hard or go home
Re: Best Glue
« Reply #9 on: July 07, 2019, 07:01:54 PM »
Pretty sure some of the top makers use animal glue
skip1973
Re: Best Glue
« Reply #10 on: July 07, 2019, 11:09:21 PM »
Don't tell the Vegans.
