Author Topic: Toe Damage - Help!  (Read 2260 times)
kurtrog
Toe Damage - Help!
« on: September 20, 2019, 01:43:27 AM »
Hey guys,
Whats the best suggestion to fixing/minimizing this damage?
https://imgur.com/qxEAZIE
Thanks in advance.
Cricket_PTY
Re: Toe Damage - Help!
« Reply #1 on: September 20, 2019, 02:08:14 AM »
Dont think u can do u much mate...
get some Super glue into the crack and sand it before it dries...
cheers..
Komdotkom
« Reply #2 on: September 20, 2019, 04:28:12 AM »
I agree, not much you can do about that. It'll be fine.
Chompy9760
« Reply #3 on: September 20, 2019, 05:21:36 AM »
Get as much glue in the crack as possible, and clamp it.  Ratchet straps over the handle/toe might work, or a weight.
If the glue doesn't hold, cut the toe back - looks like you'd only lose 5-10mm.
« Reply #4 on: September 20, 2019, 05:54:46 AM »
1. Invent time machine.
2. Return to when you bought the bat.
3. Knock it in before using it!
Wazza08
« Reply #5 on: September 20, 2019, 06:53:22 AM »
Even with knocking it in, it can still happen with the odd yorker to nice hard ball, but i a do agree that it certainly helps limit it!  It looks pretty new that bat
Mfarank
« Reply #6 on: September 20, 2019, 07:20:59 AM »
Buy a new bat!
nivaga
  • Life student of cricket now living it via my lad
« Reply #7 on: September 20, 2019, 07:51:29 AM »
Exact same thing happened to my boys bat (harrow) the other day.
Dinged the ground (concrete underneath 'carpet'?) in the nets digging out a yorker ... damage from hitting ground not ball (on video). Damage very similar to yours - just half way between centre and outside edge.
I stood some PVA glue in it overnight (level) and let that soak into the gaps.  This morning the 'dent' was about half full but the cracks at the top end were bonded.
I gave it a bit of a gentle knock with the mallet just to try and compress the damaged area (not too hard ... didn't want to force open cracks again).  I have just put a bit more PVA in to try and make it more level.  Doubt I will do any more.
I had been going to sand an older bat into the glue to make a 'filler', but this glue is clear and as a result is practically invisible. I think that unless the willow 'shade' from the other bat had been identical I would have made more of a 'cosmetic mess'.
After that I will remove and re-attach the toe guard.  It is clear based on both my and your ding that the rigidity of the toe guard at the end prevented more damage i.e. the damage is up towards the face rather than into the toe as you sometimes see. I may deliberately leave 1mm or so overhanging the face instead of trimming perfectly flush as I did last time as a small "bumper".
I will probably wrap some bat tape around the toe.  Not sure why we think edge tape on vertical edges is a good idea but not the toe which is probably weaker due to lack of less pressing to start with and being thinner(?)
My son was quite sad about his bat until I showed him pictures of international players with seriously bandaged up bats so now I think he actually wants some tape :)
KettonJake
« Reply #8 on: September 20, 2019, 08:57:04 AM »
Don't wallop yorkers!
jacob@durantcricket.co.uk
sachin200
« Reply #9 on: September 20, 2019, 04:10:07 PM »
Take the toe guard off toss it in the garbage, fill the cracks with PVA glue (wood glue) and apply a thick coat of shoe goo to the toe. That also looks a bit dry. Was it oiled and knocked before playing? I agree with previous posts - it can happen to any bat (new ball and a damn good Yorker) so stop hitting Yorkers for sixes (pros can try doing it since they have a truckload of new bats ready for them when needed).
alexevo94
« Reply #10 on: September 20, 2019, 05:16:56 PM »
It's not the new bat you bought the other week is it?
Sitonit
« Reply #11 on: September 27, 2019, 06:22:34 PM »
Hey guys,
Thanks in advance.
Pretty normal wear and tear, unless of course if you want to treat it as a potential excuse to buy another bat?
This is what you call a toe damage.
https://www.youtube.com/watch?v=XN9hPZLyyaA
« Last Edit: September 27, 2019, 07:03:40 PM by Sitonit »
