Moisture Meters & Keeley Bats
Author Topic: Moisture Meters & Keeley Bats  (Read 3063 times)
« on: November 11, 2019, 03:31:45 PM »
It is possible that this has been discussed before but I will add a thread here...
I recently had access to a moisture meter that was used on a wall. I put it against my Keeley and I got a reading. This moisture meter was set to read moisture against wood (not dry wall).
Couple of observations:
- The moisture reading was not consistent. The pingiest area (which is also delaminted slightly) read lower than other areas. 8% in general blade area and 5% close to the bottom.
- The edge read 0 % moisture but the meter was wider than the edge so...
What are your experiences with moisture meters and bats? How do bat makers measure moisture in their bats?
KettonJake
Re: Moisture Meters & Keeley Bats
« Reply #1 on: November 11, 2019, 03:39:59 PM »
My general feeling on them is they are pointless for cricket bats, and fairly haphazard in general. We have one for measuring concrete floors before laying sports surfacing. I once tried to get a reading out of a puddle on the concrete, it came back as zero.
To get any kind of reliable moisture reading, the measuring implement (usually a metal prong connected to the digital readout) needs to be driven into the material being read. As I assume you didn't bury the prong into a cricket bat, the reading will be nonsense.
Just to note there are meters that give a reading without the requirement to drive a metal prong into the material being measured, but these meters can only give a relative reading compared to another material of a known density and moisture content.
jacob@durantcricket.co.uk
« Reply #2 on: November 11, 2019, 03:54:27 PM »
Moisture meters and bats always reminds me of the "test" cricketstoreonline did, where they got a reading of 0 from a GM by measuring the scuff sheet!
As far as measuring the moisture content of your own bats, it's a total waste of time! How would you look to "rectify" it if your bat had a reading that you felt was too high or too low?
« Reply #3 on: November 11, 2019, 04:10:14 PM »
:D That made me laugh!
The meter was initially used against wall stud to check for wetness/moisture after a prolonged drying operation. I'll see if I can get the name/brand of it.
« Reply #4 on: November 11, 2019, 04:14:28 PM »
Those "blunt instrument" videos were such a "joy" to watch - nothing was ever wrong with a bat or a brand unless "blunt instrument" really really hated them. :D
Quote
That's a very interesting question. I don't know what I'd do. I suppose the utility of an accurate reading would assist with performance tracking of a bat over time (against, say, fluctuating or decreasing moisture levels).
SurreySam
« Reply #5 on: November 11, 2019, 04:23:59 PM »
A wagner pinless instrument is what JS Wright & Sons use.
« Reply #6 on: November 11, 2019, 04:28:26 PM »
Something else worth considering is the fact Willow is hygroscopic - meaning it will naturally takes on or gives off water to balance with it's environment.
On a very basic level, if you started off with two identical bats with the same moisture content, then left one in a dry house and another in a damp shed, if you checked again a week later their moisture content wouldn't be identical any more.
KettonJake
« Reply #7 on: November 11, 2019, 06:51:19 PM »
Many willow suppliers use moisture meters, but the difference is they are working with a cleft, not a finished bat.
SurreySam
« Reply #8 on: November 11, 2019, 09:02:49 PM »
By finished, I assume you're suggesting scuffed, oiled or waxed? In which case yes, the meters could be skewed by varying amounts.
If the finished bat/area is naked then a good reading could be taken, as the Wagner meters can read down to 4%. How you then translate that data into relative performance, would be interesting.
KettonJake
« Reply #9 on: November 11, 2019, 09:21:39 PM »
All bats have some degree of finishing on them. You could sand one back to white willow and then have a go. But like you said, I’m not sure what use the data would be
Jimmy Tiwana
« Reply #10 on: November 11, 2019, 10:38:26 PM »
I recently had access to a moisture meter that was used on a wall. I put it against my Keeley and I got a reading. This moisture meter was set to read moisture against wood. The pingiest area (which is also delaminted slightly) read lower than other areas. 8% in general blade area and 5% close to the bottom.
Very interesting  question and observation. Did you check the moisture content in any of your other bats?
« Reply #11 on: November 12, 2019, 12:16:30 AM »
^ No, just one. I didn't want to disrupt a profressional's day by hogging his moisture meter. :D
Sitonit
« Reply #12 on: November 12, 2019, 03:45:00 AM »
Dip and soak it in the water or leave it in the car trunk. Easy!
« Reply #13 on: November 12, 2019, 12:50:43 PM »
I have a moisture meter which has contact pads rather than prongs. I find it’s comes out with measurement in light with the normal cleft % willow suppliers aim for. Must admit, I’ve never tried it on a finished bat though, only ever at cleft stage
