Show off your Keeleys!
Pages: 1 ... 13 14 [15] 16 17 ... 21
Author Topic: Show off your Keeleys!  (Read 84155 times)
Re: Show off your Keeleys!
« Reply #210 on: June 15, 2021, 11:00:59 AM »
And a strong lad, otherwise no point 😃😃
A full profile bat is pointless unless you're strong? What are you basing that (nonsense) opinion on?
Jaffa
« Reply #211 on: June 15, 2021, 11:05:48 AM »
Our clubs Keeley sponsored player has broken three bats.
Don't know the circumstances but he looks after his kit and faces decent balls. They were replaced without question but anyone else had Keeleys break sooner than expected?
« Reply #212 on: June 15, 2021, 11:12:42 AM »
What weight do you use? Full profile? Jim.
I guessed this particular bat weights 2lb 11oz. If it turns out to be 2lb 8oz then it's another story 👍
« Reply #213 on: June 15, 2021, 11:24:03 AM »
I use full profile, 2-10ish bats. I am neither a particularly large or strong batsman.
So you've taken a wild guess at bat weight, assumed that only a large/strong batsman could use such a weight and based your assessment on that? Surely you realise how absurd that sounds.
Luke-scicc
« Reply #214 on: June 15, 2021, 12:30:31 PM »
Come on Jimbo surely you can see from that photo it's obviously a 2.11 bat!  ;)
« Reply #215 on: June 15, 2021, 12:52:10 PM »
I've not really had many issues with Keeleys breaking - what were the breakages like? Handle or toes?
It's daft to assume where a batsman would bat based on the bat make and weight.
The only guarantee is that all tailenders use Gray Nicolls that weigh 2lb9oz. They even have a bat model called the Tailender.
« Reply #216 on: June 15, 2021, 01:22:17 PM »
[/quote]
You read it wrong, point is that batsmen pick their weights according to the kind of bowling they face, majority of the time.
You'll have an opener using 2lb 13oz, but that's not common.
On the other side, not all tailenders use 2lb 9oz!
Simply not true 🙂
« Reply #217 on: June 15, 2021, 01:31:54 PM »
Simply not true 🙂
I would suggest you missed @Chad sarcasm in his previous post.
Assuming the weight of someone’s bat purely on there size/batting number is completely outrageous. I’ve seen guys built like a racing snake use 3lb bats, as well as guys that are strong fellas using 2lb7. It’s all about what you are comfortable with. Not what AJ on the forum assumes what you use.
Grubby
« Reply #218 on: June 15, 2021, 02:00:51 PM »
There is the 'ignore user' functionality which I find works as the best way to filter out most of the ridiculous comments.
SouthpawMark
« Reply #219 on: June 15, 2021, 02:37:23 PM »
If this forum had a rolling eyes smiley, I would be using it now.
Bat perv.
e4sby
« Reply #220 on: June 15, 2021, 03:06:44 PM »
So finally got this special Keeley in my possession... very lightly used, the odd mark/dent, did have some binding on toe that was removed by the last owner.
Bat weighs 2.12 and fills the gauge. Now need to decide whether I try and use it in its current state or send to Keeley... the bat could do with a decent clean up...
So…
I’ll do my best to get the thread back on track with a few more photos…
So decided to send my pro bat Keeley off to get a couple of ounces taken out of it. Less than a weeks turnaround and £40 I’ll let the photos do the talking…
Used for the first time last night and hit a monster slog sweep 6 (for me)
« Reply #221 on: June 15, 2021, 03:17:28 PM »
What a beaut @e4sby what did you get it taken down to weight wise? Still looks a very good size.
e4sby
« Reply #222 on: June 15, 2021, 03:40:42 PM »
2.12 down to 2.10 with two grips, still a very decent size, 39mm edge 60mm spine
ppccopener
« Reply #223 on: June 15, 2021, 05:45:19 PM »
Thanks that’s worked hopefully
« Reply #224 on: June 15, 2021, 06:14:52 PM »
I really wish my phone had an 'Ignore Forum' button. (And, yes, I'm guessing quite a lot of you wish it did too).
It's like a car crash:  really terrible, but you can't help looking.
