Bat repair room
Author Topic: Bat repair room  (Read 5931 times)
Re: Bat repair room
« Reply #15 on: January 12, 2020, 07:01:39 PM »
Mighty
Re: Bat repair room
« Reply #16 on: January 12, 2020, 07:03:40 PM »
Medium risk,,, ie wood dust
Re: Bat repair room
« Reply #17 on: January 12, 2020, 08:38:43 PM »
Hook it up to a Hoover that’s better than nothing,,,, but please do your lungs a favour and upgrade when you can.
Most building sites now specify m class extraction for a reason
Any particular recommendations?
Re: Bat repair room
« Reply #18 on: February 28, 2020, 07:07:41 PM »
Room is slowly coming along. Will stick up some pics at some point.
Next stop is a bench (plan to built one into the wall) and a vice. Will just a regular heavyweight(ish) metalworking vice with some magnetic soft jaws do the job?
Only photo I have so far, used all out left over hardwood flooring. Have gotten the walls up now.
« Last Edit: February 28, 2020, 07:49:20 PM by Kulli »
Re: Bat repair room
« Reply #19 on: February 28, 2020, 07:22:03 PM »
Yep just a solid standard vice (6in+) then either add soft jaws or replace the jaws with some wood inserts. Depending on your workspace then a vice that pivots can make life a lot easier. If you get soft jaws then I'd recommend getting fibre ones - the rubber ones are still tough enough to mark up willow.
