Bat Weight Optimisation
Author Topic: Bat Weight Optimisation  (Read 2658 times)
singapore rookie
« on: May 20, 2020, 03:15:14 AM »
If you want to reduce the weight from a given bat profile, which one of the following is a better option:
Size of the edge
Size of spine
concaving
blade length
Re: Bat Weight Optimisation
« Reply #1 on: May 20, 2020, 05:22:35 AM »
Surely all of the first three and arguably the fourth would make it a different profile? Just slightly smaller all over would be the way to keep the same profile at lower weights, a la B3.
singapore rookie
« Reply #2 on: May 20, 2020, 05:37:42 AM »
so is it better to reduce all the three proportionately or better to give up edge vs spine/spine vs concaving/edge vs concaving ?
Jaffa
« Reply #3 on: May 20, 2020, 07:15:22 AM »
I'd say try thickening the handle and adding a counter weight before modifying the bat.
While increasing the weight, you're improving the pickup and that works for some.
« Reply #4 on: May 20, 2020, 07:24:02 AM »
Weight reductions in my opinion should be small changes to every dimension of the bat. Otherwise as Ed says you just change the profile and may as well buy a new bat.
sgcricket
« Reply #5 on: May 20, 2020, 08:02:24 AM »
Size of the edge
Size of spine
concaving
blade length
The answer depends on why you want to reduce the weight in the first place. If you are looking at the bat picking up better then shaving weight from the bottom is the way to go. You would cut off the shoulders if you wanted the opposite.
singapore rookie
« Reply #6 on: May 20, 2020, 08:34:03 AM »
I am getting a custom bat made and was looking at a profile, for the density of wood I cannot get it in the weight I want.
If I want the Tendulkar/TKC/Finch/Shan profile I cannot get it in 2lb8oz, so I am trying to figure out what is the best way to get the weight down.
« Reply #7 on: May 20, 2020, 08:34:24 AM »
Surely depends on how the bat is now and what you're hoping to achieve? If its got a very thick toe and you want to improve pick up, you can take some from the toe. If it's full with big edges and you just want to just make it lighter, you add some concaving etc without sacrificing edge size if this was something you want to keep.
Jaffa
« Reply #8 on: May 20, 2020, 08:46:23 AM »
If it is pure weight loss you want and don't want to alter the profile you can always drill out from the splice. That's what Hunts have been doing for years and it can remove about 2oz apparently.
« Reply #9 on: May 20, 2020, 09:06:34 AM »
Anyone had this done successfully with the toe of their bat? Got an absolute monster of a Kippax I haven't properly used yet but it picks up quite bottom heavy and wondering if this may be the way to go.
« Reply #10 on: May 20, 2020, 09:24:05 AM »
By the sound of the profiles you are looking at, seems like you could be looking for B3 to make the bat for you? Great choice if so!
Could you not just ask them to take a mm (Or as many as you like) off the dimensions of the bat? I think I remember Streaky saying that a mm off the bat was eqivalent to an ounce.
« Reply #11 on: May 20, 2020, 09:33:02 AM »
Have you asked them? Other forumites haven't had a problem getting those shapes in 2lb 8: http://custombats.co.uk/cbforum/index.php?topic=45890.0
singapore rookie
« Reply #12 on: May 20, 2020, 10:19:49 AM »
I haven’t had the discussion with them but wanted to get an opinion from the forum.
The Shan one was achieved with a shorter blade and long handle set up.
Butterfingerz
    • Stealth Cricket
« Reply #13 on: May 20, 2020, 10:50:17 AM »
Size of the edge
Size of spine
concaving
blade length
Lets have a chat and discuss the options and what works for you. Send me an email with your contact details and we can schedule something - richard@b3cricket.com
