Cleft density
Author Topic: Cleft density  (Read 15213 times)
Mfarank
Cleft density
« on: May 25, 2020, 04:20:35 PM »
Can someone please enlighten me as to how B3 calculate the density of their clefts? I know the basic idea is mass/volume but what is the unit?
Mfarank
Re: Cleft density
« Reply #1 on: May 25, 2020, 04:59:56 PM »
After playing around with the units of a cleft i have come up with the mass as 60.85 ounces and a volume of 0.1431 cubic feet. And the number was 425.3 so i am guessing this must be it
Re: Cleft density
« Reply #2 on: May 25, 2020, 05:14:22 PM »
You’re on the right track but 425 is impossibly low density (based on what I recall). But it’s definitely in the 400s so you’re within the ballpark.
Mfarank
Re: Cleft density
« Reply #3 on: May 25, 2020, 05:16:54 PM »
Looking at a few of the trott posts people have had clefts under 400 so surely not impossibly low density.
Re: Cleft density
« Reply #4 on: May 25, 2020, 05:23:43 PM »
Wasn’t 400 their starting point for an average cleft?
Mfarank
Re: Cleft density
« Reply #5 on: May 25, 2020, 05:25:36 PM »
I assume so as im talking about the whole cleft pre-handling and shaping
Re: Cleft density
« Reply #6 on: May 25, 2020, 06:05:50 PM »
Oh sorry. My bad. You guys are right.
bigblue365
Re: Cleft density
« Reply #7 on: May 25, 2020, 08:01:54 PM »
How is the density calculated?
Re: Cleft density
« Reply #8 on: May 25, 2020, 08:14:33 PM »
Kg/m^3, I'd guess
« Last Edit: May 25, 2020, 08:16:29 PM by edge »
Mfarank
Re: Cleft density
« Reply #9 on: May 25, 2020, 08:41:46 PM »
Mass over volume is the formula. Units is the key. The most commonly used metric units for density are kg/cubic meter and when i put the values in the answer was 425.7
Incidentally when i switch to imperial units (cause you know God save the Queen) and calculate with oz/cubic feet the answer is almost the same (425.3) so it must be one of the Two
« Last Edit: May 25, 2020, 08:44:02 PM by Mfarank »
Re: Cleft density
« Reply #10 on: May 25, 2020, 08:52:47 PM »
Exactly? It shouldn't be... On the subject of units, the UK is not America, we may use imperial units on road signs but you won't find them used for actual work.
Mfarank
Re: Cleft density
« Reply #11 on: May 25, 2020, 08:55:14 PM »
Corrected to "almost" the same  :D this was a fun excercise for revising high school math. I had forgotten how to calculate area of a triangle
Psi
Re: Cleft density
« Reply #12 on: May 25, 2020, 11:32:51 PM »
Yeah but we do quote bat weights in pounds and oz don't we???
LDifa
Re: Cleft density
« Reply #13 on: May 26, 2020, 07:38:13 PM »
from memory average density of a cleft was 400
If a shape you liked was 2lb 10 but you wanted 2lb 8 then you could need a lower density - i think a density of 10 was an ounce
favourite shape at 2lb 8 would need a 380
Chalkie
Re: Cleft density
« Reply #14 on: May 27, 2020, 12:05:10 PM »
I think this is correct as had a couple of B3 bats under 400, one as low 369.
Copying in @Butterfingerz for an official response
