Oiling New Bat
Poll
What part of a new bat do you oil?
All over
- 16 (69.6%)
Face and edges up to labels
- 6 (26.1%)
Other
- 1 (4.3%)
Total Members Voted: 23
Author Topic: Oiling New Bat  (Read 3178 times)
Grubby
Oiling New Bat
« on: June 03, 2020, 06:51:11 PM »
A friend and I have had a discussion on oiling a new bat. We have differences. What do people do to theirs?
Re: Oiling New Bat
« Reply #1 on: June 03, 2020, 06:53:36 PM »
Oil it all over, then knock it in, then apply a scuff sheet.
GDP1964
  • GDP
Re: Oiling New Bat
« Reply #2 on: June 03, 2020, 07:18:07 PM »
Bat Wax is they way I go
potzy248
Re: Oiling New Bat
« Reply #3 on: June 03, 2020, 08:15:00 PM »
Never Oil my bats.
Canners
  • go hard or go home
Re: Oiling New Bat
« Reply #4 on: June 03, 2020, 08:19:41 PM »
Never oil mine tbh
Canners
Re: Oiling New Bat
« Reply #5 on: June 03, 2020, 08:24:20 PM »
I also never understand why people knock it in and then put the scuff on?
I would think you want the scuff on whist the face is flat and untouched so the scuff sticks to a flatter surface area
Re: Oiling New Bat
« Reply #6 on: June 03, 2020, 08:26:53 PM »
Just a little bit on new bats to prepare the surface for knocking and also seal moisture in.
I do apply oil to older bats, all over, to maintain moisture. My old bats look like "chips" as Julian Millichamp would say. ;)
Re: Oiling New Bat
« Reply #7 on: June 03, 2020, 09:56:31 PM »
Never used oil as in linseed oil from a bottle, always use bat wax and normally apply a single light coat to a new bat and then at the start of each season remove the scuff sheet, sand lightly and apply bat wax sand then add a scuff.
Also most of the bats I get have a scuff on already but if not I apply a scuff before “knocking in” prep work which nearly always is done on the Bola machine.
Re: Oiling New Bat
« Reply #8 on: June 03, 2020, 09:59:16 PM »
Because if you put the scuff sheet on before knocking the bat I'm you end up with air bubbles when you round the edge.
Also a properly knocked in bat will be evenly compressed over the surface will be flat and the scuff sheet will stick fine
Canners
Re: Oiling New Bat
« Reply #9 on: June 03, 2020, 10:44:31 PM »
Never ended up with any air bubbles on any of my bats that have had the faces applied straight away.
I also think knocking in only needs to be minimal on a properly pressed bat.
I knock the toe in for a bit and give it a bit of a whack more to test the ping and then go and use it
Re: Oiling New Bat
« Reply #10 on: June 04, 2020, 12:20:00 AM »
I absolutely HATE pale white bats (it’s become a fashion these days) and love the nice light golden tinge an oiled bat has. Most new bats don’t need much oil these days, and over oiling can ruin a bat...so just about a teaspoon should be enough. Sometimes I use much less (just soak my fingers and rub them over), just to get that nice colour.
