When buying a bat, what to look for
Author Topic: When buying a bat, what to look for  (Read 5029 times)
« on: September 23, 2020, 09:50:34 AM »
I have just watched a kit video with a review of some bats.
And to be honest the review didn't cover any of the main things I look for in a bat.
Plus the other day I was asked in a shop what I looked for and I couldn't answer. At the same time I was choosing a bat and subconsciously went for a few things in a certain order... So I thought I would bullet them out.
1. Weight, when picking a bat I look for a bat in my weight range. (2lbs9 - 2lbs 11) if you are in a shop that will narrow down your selection. As will...
2. Middle position, I like a mid to low bat shape without at most very little concaving, I also like the spine to be straight and not off centre...
3. Handle. Is it well fitted and quite stiff. I will look to check that the springs straight and even. Is it a 9 or 12 piece handle. (note shape can be changed). I don't really like the cheap 4 piece handles or the Pak ones with about 7 springs in...
4. Grains and face of the bat. I like a bat with character, happy to have butterflys etc, but I look for evenly spaced grains, going evenly and pretty straight through the toe. I want, ideally, a clean hitting area, but sometimes some graping can really add to performance. I don't like pin knots or other dead spots in the hitting area.
5. Pick up. This is personal, not much to say. A light cleft can feel amazing, but they are usually out of my price range these days. Oh and thick shoulders are usually a good sign for pick up.
6. Performance, remembering that this can improve, but sometimes it just won't.
What do you look for?
« Last Edit: September 23, 2020, 10:49:56 AM by Buzz »
Re: When buying a bat, what to look for
« Reply #1 on: September 23, 2020, 10:05:48 AM »
I am pretty much the same, though more 2.8-10.
My current match bat has an off centre spine which I found when replacing the stickers. Doesn't seem to make much difference. Something about personality....
JTtaylor145
« Reply #2 on: September 23, 2020, 10:08:19 AM »
When going into a shop/bat makers
1. Weight (between 2lb 9ozs and 2lb 11ozs)
2. Full profile, if possible
3. Balance/Pick up (wearing gloves)
4. Response against the mallet
5. Response when tapping up an old ball
6. 8-10 grains if possible (even spaced and going through the toe)
7. Reasonably thick handle (GM and Aldred handles are a good guide)
« Reply #3 on: September 23, 2020, 10:11:57 AM »
Pick up wearing gloves is a good shout. I forgot that.
« Reply #4 on: September 23, 2020, 10:23:27 AM »
Since getting my BB and having to tape and glue the shoulder on a number of occasions, a reasonably sturdy shoulder and toe are definitely a consideration now.
« Reply #5 on: September 23, 2020, 10:51:21 AM »
Also remember that while a 2.13 might pick up lovely in a shop, it might not feel the same after 20 overs of lifting it.
« Reply #6 on: September 23, 2020, 11:07:11 AM »
In priority order:
1. Pickup - let's be honest, if you don't like the way a bat picks up it's going straight back on the shelf. Needs to be balanced, too light in the hands is a hard no but don't want it bottom heavy either.
2. Handle - if it's thin and round I'm not buying the bat. Needs to be thick enough for my liking and ideally a decent oval.
3. Shape - I like a forgiving middle so always look for a long spine up and down the bat with a bit of wood left in low down (no duckbills!), mid middle.
4. Weight - I know what the limit of what I can swing is pretty well which is around 2.11 before adding second grip, scuffs etc., so I'm usually pretty firm about staying around 2.10-11.
5. Performance - as best I can judge it with a mallet/old ball anyway. Realistically you're just looking for it not to be a plank at this stage, but happy to be surprised with something that feels really nice.
6. Grains - what I mostly look for is grains that stand out and are fairly straight. Narrow/wide is all the same to me, but there's a certain quality I look for that doesn't let me down (I think, anyway!). Ideally a clean face and straight through the toe, do like a butterfly but you don't see many of those in shops.
Realistically there are things I'll compromise on and things I won't. Having the pickup and handle how I like them are the real must-haves, with shape and weight I'm a little more open-minded and looks are definitely secondary to whether I like the bat or not. Judging performance of a brand new bat before you use it? I think you're probably kidding yourself, so while I'll always check I don't set too much faith in that unless it makes an extreme impression in either direction. Once I'm really interested I'll always try with gloves on and always with a second grip.
KettonJake
« Reply #7 on: September 23, 2020, 12:11:13 PM »
I tired to ensure every customer did this at Vitas Cricket, if they didn't bring their own they were swiftly issued a pair.
jacob@durantcricket.co.uk
Mfarank
« Reply #8 on: September 23, 2020, 12:15:40 PM »
just bought a MIDS ZH power bat couple of days ago from a local retailer. will review it soon. it was the first time in a very very long time that i picked out a bat myself from a large selection and had the luxury to physically check them out so i think i can add to this topic.
-the first thing i did was filter out all the bats that were beyond what i was willing to pay. in my case DHS. 600 or GBP 120
-the next thing i did was pick out the bats that had straight-ish (at least 6) grains and a playing area clear of knots or blemishes (butterfly stains are encouraged).
-then i proceeded to pick up each of those bats and shadow practiced drives and cuts to filter out those that felt too heavy
-at the same time i also filtered out those that had very thin round handles.
-once i was down to about 4-5 bats, i tested the ping with an old ball and filtered it down to the 3 best pingers
-finally i took those 3 to the scales and compared the dead weight, edge thickness, toe thickness and amount of concaving
-the one i ended up selecting had the biggest edge size, thickest toe and lightest weight on the scales
edit: I also made sure the bat i ended up buying had a full 107-108mm wide face cause narrow bats is a thing now
« Last Edit: September 23, 2020, 12:22:54 PM by Mfarank »
« Reply #9 on: September 23, 2020, 01:46:05 PM »
Feel and white wood by and large
Feel is key  but my bat's tend to be around 2-7 to 2-9 pick it up look down it and hey presto.
Grains I do not really care for mean nothing (vanity)
Feel
Ping not really 90 per cent maybe higher have same effect in the right hands
Do prefer a much higher middle bat pick up is all important but feel with or without gloves on
If I'm in a shop I tend not to have a massive choice either get in there early it funny I did a experimebt with a customer once who was picking up bat's for two hours in the end he got tired and started picking lighter bat's!!!
« Last Edit: September 23, 2020, 01:48:32 PM by procricket »
« Reply #10 on: September 23, 2020, 02:25:56 PM »
Pick up and.  Handle shape are the two things for me. I would pick a 5 wavy grain bat over a 10 dead straight all white sapwood blade if the handle was better.
I also feel that the pressing and QC of the brands I’ve used over the last 5/6 seasons (GM, GN, Salix G&F) has meant I haven’t had a plank and can count on one hand the badly performing bats iv had so I trust that all bats will to the club player play the same and I don’t think you can gauge accurately how a bat will perform from tapping a ball in a shop or via a video of a mallet response but gives an indication I guess with more and more now buying blind due to lack of available retail stores that stock quality cricket equipment
« Reply #11 on: September 23, 2020, 02:41:38 PM »
Weight - I can generate the kind of bat speed I like. Also, not heavy for a long inning. 2-10 and not exceeding 2-11. Too light, my timing goes off; too heavy, I am late in my shots.
Middle - Mid/mid-low middle; I know where I hit the ball on the bat face.
Bow - Big bow as it assists in playing lofted shots.
Handle - thin, oval. The bat has to feel right in my hands. If my grip is not right, it doesn't work for me.
Sound off the mallet - don't care.
Ball rebound on bat face test - don't care; until I use a bat in the nets, there is no guarantee that a nice bouncey bat will work me. I have a 32 grainer trampoline sitting in my house that I can't time the ball to save my life!
Grains - don't really care as long as the bat pings.
Blade length - Shorter blade lengths than SH work well for me.
« Reply #12 on: September 23, 2020, 03:04:13 PM »
Aware of your thoughts on this from previous topics, but I'd be interested to hear what blade lengths you've used and whether you had a correspondingly shorter handle? I've been using Harrow size bats this year and I've been much more comfortable playing a range of shots, rather than the fairly limited repertoire I seemed stuck with using standard SH.
roco
« Reply #13 on: September 23, 2020, 03:04:37 PM »
2lb9 naked then pick up and dull sound when hitting a ball (no idea why just always served me well)
Also like this shoulders
« Reply #14 on: September 23, 2020, 04:20:47 PM »
I put all the details in this thread with pictures.  Let me know if you have questions, I'd be happy to help.
http://custombats.co.uk/cbforum/index.php?topic=46757.msg753493#msg753493
