Root Profile.
Author Topic: Root Profile.  (Read 6494 times)
Nate
Root Profile.
« on: January 22, 2022, 08:11:32 PM »
Hi All,
Looking to pick up a root bat from B3 in the near future similar to what @Canners and @LEACHY48 have but can’t get the number on the handle off them. Does anyone else have one and could share some photos of the bat along with the number on the handle.
Thanks
Re: Root Profile.
« Reply #1 on: January 22, 2022, 09:02:50 PM »
Hi All,
Thanks
The 32.2 or “maverick” is a slightly concaved (2mm) version of the root profile. Am 99.9 percent sure of this, but you can check with them. You can then ask for zero mm concaving instead of 2mm, but I’d personally stick with the 2mm - it is barely noticeable and actually enhances pickup.
Re: Root Profile.
« Reply #2 on: January 22, 2022, 09:09:57 PM »
Have you tried asking B3 themselves?
Re: Root Profile.
« Reply #3 on: January 22, 2022, 09:12:57 PM »
I would second this, I've called B3 up a few times and they were unfailingly helpful.
Nate
Re: Root Profile.
« Reply #4 on: January 22, 2022, 09:21:42 PM »
I haven’t yet, thought I’d try all you bat badgers here but that was going to be my next port of call.
Re: Root Profile.
« Reply #5 on: January 22, 2022, 10:26:05 PM »
7980 I believe
Nate
Re: Root Profile.
« Reply #6 on: January 22, 2022, 10:30:33 PM »
7980 I believe
Who’s bat is that @ch1p, do you know?
velvetsky01
Re: Root Profile.
« Reply #7 on: January 22, 2022, 10:46:06 PM »
Yep 7980
I bought this from Jake (no longer have it)
Only issue with this is that it was an extremely low density cleft so might not be readily available
HS: 119*
Best Bowling 7.4-1-32-6
Nate
Re: Root Profile.
« Reply #8 on: January 22, 2022, 11:01:00 PM »
Yep 7980
Thanks for that, I’m not familiar with people on the forum.... is Jake @LEACHY48?
