Harrow CA
Author Topic: Harrow CA  (Read 9149 times)
Cfjames137
Harrow CA
« on: April 18, 2022, 04:36:44 PM »
Evening all, just a quick question on CA bats. I currently use a kook Small adult due to weight and handle length. I like the CA bats but seem like a light one is very rare, anyone used or held a Harrow and can comment how they feel? Cheers
Re: Harrow CA
« Reply #1 on: April 18, 2022, 04:51:57 PM »
How light do you need? If you're UK based then worth checking out DKP Cricket as they usually have a very good selection of Asian brands and I've definitely seen some 2'7 CA bats in their stock before.
Cfjames137
Re: Harrow CA
« Reply #2 on: April 18, 2022, 05:07:48 PM »
 Cheers for that, yes I am in U.K. I’ll have a look on dkp and I want something around 2’6 or 2’7.I saw some plus 15000 juniors on The cricket shed and they were offering options of 2.7 2.8 etc so was wondering if these heavier weights on harrow blade would be worth trying
Re: Harrow CA
« Reply #3 on: April 18, 2022, 05:14:46 PM »
My problem with Harrow bats is even in the heavier weights you get very very thin handles and thin shoulders. I had a quick look and DKP have at least two models of CA in 2'7 at the moment.
Re: Harrow CA
« Reply #4 on: April 18, 2022, 06:13:29 PM »
I'd be sure to clarify they're 2lbs 7oz and not 2.7lbs, as some subcontinent brands measure weights this way.
Away from CA, you could always look at going custom and getting a full width but harrow length bat made up at your specific weight etc
Kai
Re: Harrow CA
« Reply #5 on: April 18, 2022, 07:25:44 PM »
Second this, our forum sponsors can help you out. @jonny77 or @Northern monkey will also do a cracking job if you decide to go down the custom route.
Re: Harrow CA
« Reply #6 on: April 18, 2022, 08:39:43 PM »
My son has a Keeley Harrow which is 2lbs 2 and not that much smaller than an SH. (slightly narrow and a couple of cm shorter). It is Indian made, but has a decent handle. Worth checking.
Re: Harrow CA
« Reply #7 on: April 19, 2022, 06:47:02 AM »
Won't a CA be harrow as standard anyway? Never seen a full size one.
Wozaboxa
Re: Harrow CA
« Reply #8 on: April 19, 2022, 09:59:12 AM »
I'll give first hand testimony of a 2.6 I had off Jonny for my lad, it's as light as a feather, SH and an absolute Cannon!
