A topic to polarise opinion.....'Specs' are they all that?
Pages: [1] 2 3 ... 8
Author Topic: A topic to polarise opinion.....'Specs' are they all that?  (Read 15489 times)
« on: August 30, 2022, 05:27:16 PM »
As its pretty quiet on here at present, i thought I'd try to start a topic to hopefully get people engaged in discussion.
So, as the title suggests what are your thoughts on specs? Are they important? If so which ones? If so why? Are they a negative? Etc etc.
Interested as a batmaker to get people's thoughts, as it seems a lot of people now chase specs over anything else. So thought it would be an interesting topic to discuss....
bigc92
Re: A topic to polarise opinion.....'Specs' are they all that?
« Reply #1 on: August 30, 2022, 05:51:55 PM »
After owning many bats new and old. For me I think it’s all in the pressing. Yes, if it has more volume then it helps but I do think bat speed is more important as well. All well and good if the bat maxes out the gauge but if you can’t swing it then it’s pointless. I’d rather something at 2’8 that’s pressed well so I can get some decent bat speed and time it.
Thamesvalley
« Reply #2 on: August 30, 2022, 06:12:59 PM »
Why does anyone need edges bigger than 37 mm , does it make the ball go further
How much more wood can you pack up higher to the bat and handle so make it pick up better with edges at 37mm as opposed to 40 mm ?
potzy248
« Reply #3 on: August 30, 2022, 06:19:42 PM »
I like fuller bats but understand that some concaving is needed to get it down to lighter weights. Concaving got out of hand though around 2010.
Weight is important to me even with so many saying pick up is the most important thing.
« Reply #4 on: August 30, 2022, 06:32:22 PM »
Think that's a good question. People seem to be under the impression it does, but I'm yet to hear or see anything which proves this. In fact, some research seems to suggest bigger bats don't equal bigger sweet spots or bigger hits.
six and out
    • MKCC website
« Reply #5 on: August 30, 2022, 07:53:11 PM »
For me it's all about quality of willow (doesn't necessarily mean grade) and the pressing.
Then add to that a well balanced bat, you should get a great pick up for it's weight.
« Reply #6 on: August 30, 2022, 09:30:50 PM »
I definitely think there's something to be said for a thick shoulder and toe for longevity. Big edges don't hurt but I'd rather see a nice full profile.
« Reply #7 on: August 30, 2022, 09:36:31 PM »
Just to play devil's advocate, is a thick shoulder any use if the handles terrible? Or a 30mm toe any use if the willow is overly dry and therefore more prone to crack?
I see people measuring specs in various places and looking for certain measurements, but i often think is it futile without looking at the bigger picture. Just a thought.
« Reply #8 on: August 30, 2022, 10:02:12 PM »
As long as you don't have a ridiculously thin splice, toe or handle - they don't make a huge difference. That being said, if 2 bats come in at the same grade, weight, tapped up around the same - I'd go for the bigger one - purely psychological. (Assuming no storm damage or drying cracks etc)
In the end, a cricket bat is a tool which is made with a bunch of compromises and enhancements:
  • Want a thicker handle? Better pick up/feel in stance, and more stiffness, but more dead weight and less feel when playing the ball
  • Want a more imposing looking swell? Increased confidence, arguably increased power in the swell zone, but reduced toe and shoulders - meaning reduced durability
  • Want a large swell, large shoulder and large toe? Sure, more dead weight, good durabi - oh, you want it 2.8 and busting the gauge? Narrowed, straw-like handle and overdried.
Things that really matter are quality of the materials used, the quality of the craftsmanship in the press, handling, shaping and balancing, and ultimately that you feel great with the bat in your hands at the crease. Size, like looks, is mostly vanity.
Sheesh, I went on a bit of a tangent - don't read below the line if you don't want to bore yourself to death... And yes, I am a little hypocritical in a way as I do have a fair few gauge busters - it's not an expectation of mine, but I am robbing some 2.6 users of their clefts...
Just my 2 cents after travelling around a bit and picking the brains of some batmakers:
A cricket bat can be split into the components which make it:
Handle
Binding
Glue
Cleft
For the handle, you'll have various factors like number of pieces, number and type inserts, etc etc. A stiffer handle will give you more power, but less feel, and a whippier handle will do the opposite to an extent. Key is to use a well made one which doesn't flex too much. And as a general rule of thumb, cork inserts = stiffer, rubber inserts = more flex/dampening. A high quality handle for me would be one with a bit of flex, but generally speaking solid, well glued together and well made with no gaps inside. (Appreciate it's near impossible to check for gaps inside a handle, but if the manufacturer is known to make good handles, you're generally in good hands.)
For the binding, something which you can wrap round the handle with a good amount of tension without snapping is pretty much what you need. Handles are glued together, so the binding will hold it together for longer. If you're the type to remove binding from your handles, make sure to at least wrap it tightly with some fibreglass tape or something!
For the glue, people used to use animal glue as it set super fast. From what I've read, it is susceptible to decay over time, but yet to hear someone say much about it with regards to it being an issue in cricket bats. With the number of older bats still around, with handles still intact, I'd say that it isn't an issue for bats. Wood glue is the most commonly used adhesive these days, and does the job.
Then for the cleft, many different batmakers say different things, but in general, what I've heard is:
  • Bats with pressing cracks and storm damage tend to go like absolute clappers
  • Grains don't really mean much
  • Surface level blemishes don't do much - if anything, in the right spot can enhance a bat
  • Low density means you can't quite get as much volume out of a cleft - it compresses a bit more, hence you will have a smaller cleft to work with overall. (Will still make a lighter bat for the volume) Low density also tends to break easier. (Less material/moisture in the blade)
  • They need to be pressed, no matter what some people say about pros not getting bats pressed and purely prepped by knocking in.
Then you have the craftsmanship/knowledge applied. Here's where things get a bit funny, as every batmaker has a different experience with working with willow. I've had one maker tell me that the softer pressed bats went better after knocking, but didn't last, and hard pressed bats wouldn't get the ball off the square, but lasted a decade, and there was a happy medium in there. Others telling me that they would never press soft. Also had a maker tell me they concaved some bats in order to get a bit more whip/feel out of them, as they would feel too clunky otherwise.
In the end, any batmaker worth their salt should be able to press a bat well and should be using good quality materials. I guess it's up to the consumer to decide which batmaker's philosophy matches up to what they expect from a bat. I'm not gonna tell what people should or shouldn't expect, but don't be unrealistic - not every bat can be a gauge buster unless you want to use a heavier bat - in fact, the gauge has made things worse for some batmakers. If you look at bats pre-gauge, a concaved bat would have thick edges and a decent spine, and a convex would have a smaller edge and spine. Now some just expect the best of both worlds. Why are smaller and more custom batmakers expected to make bats that the bigger brands charge £600 for at half the price? And why do you deserve to get a cleft which would gain me a customer who uses 2.6 who would pay the same? (Again - I realise the hypocrisy)
« Last Edit: August 30, 2022, 10:04:16 PM by Chad »
Thamesvalley
« Reply #9 on: August 30, 2022, 10:03:19 PM »
This makes total sense
There’s little point having a 37 edge and more weight towards the handle whilst the handle is made of that soft white stuff inside
Just been looking at the Kent chap who’s 40 plus and his Keeley isn’t huge
Saying all this 99 percent of customers don’t seem to care .. this forum is made up of the 0.5 % or much less
« Reply #10 on: August 30, 2022, 10:38:36 PM »
Some? Quite a lot I'd have thought?
« Last Edit: August 30, 2022, 10:46:23 PM by Bats_Entertainment »
« Reply #11 on: August 30, 2022, 10:40:36 PM »
You should have sought out Big Ginge while you were at the Test match. He has quite strong opinions on this.
« Reply #12 on: August 30, 2022, 10:48:39 PM »
* Basically he's thinks it's BS.  ;)
« Reply #13 on: August 31, 2022, 01:46:59 AM »
Specs are only important if the batter feels it gives them more confidence as cricket is more a mental game than anything else.
In my view if your bat has 40mm edge, 30mm toe etc it won’t hit it further than a 25mm edge etc as that’s all down to how well it’s pressed and crafted.
Specs are purely to give people confidence.
« Reply #14 on: August 31, 2022, 06:19:10 AM »
All else being equal, a bigger bat will hit the ball further. That said, it's very unlikely you'll ever be choosing between two otherwise identical bats that are notably different in size, so it's a bit of a moot point anyway.
I think you can't blame people buying remotely too much for wanting to spec up their bat precisely, as it's their best way of trying to get what they want (or what they think they want). That said, someone who won't buy a bat because it's got 38mm edges not 40mm is being a bit daft.
