Author Topic: New handle design  (Read 7620 times)
Tom
New handle design
« on: February 02, 2023, 03:01:07 PM »
Grays are working on a new handle design, which will do away with a traditional splice. The design is essentially a hollowed out cavity within the bat, which runs down to around 15mm short of the toe, which reduces weight.
The handle is then created in a circular form and inserted and glued into the cavity, and runs about 1/3rd of the way down.
Could look something like this (though the cavity shape/size/position can differ)
More pics and docs on the patent website here, click drawings and description to see them:
https://register.epo.org/ipfwretrieve?apn=AU.2022203712.A&lng=en
Re: New handle design
« Reply #1 on: February 02, 2023, 03:42:32 PM »
Will be interesting to see if that meets the blade has to be made of one piece if wood law...
e4sby
« Reply #2 on: February 02, 2023, 03:52:16 PM »
I presume the depth of the proposed new handle will be similar depth to the current spliced handle
« Reply #3 on: February 02, 2023, 04:02:26 PM »
Interesting. Didn't they have something like this before many years ago? The hollowed out correct isn't anything new though, been done a fair bit i think previously.
« Reply #4 on: February 02, 2023, 07:24:07 PM »
Hunts have definitely had hollowed bats - I think the Turbo had a hole drilled through the bat from top to bottom.
« Reply #5 on: February 02, 2023, 08:21:40 PM »
I think I read that, at one point, they were making all their bats like this.
« Reply #6 on: February 02, 2023, 08:23:53 PM »
I also remember reading Mark Rapmrakash saying how he wished a batmaker would invent a detachable handle.
potzy248
« Reply #7 on: February 02, 2023, 08:29:08 PM »
And if the handle breaks? Do you have to drill out the old one?
billyb
« Reply #8 on: February 03, 2023, 05:42:07 AM »
Does handle innovation ever really take off?
Kez
« Reply #9 on: February 03, 2023, 10:46:03 AM »
Correct Hunts basically do the same as the diagram but splice the handle as normal.
kesoncricket.com
Tom
    • www.cricketinsight.co.uk
« Reply #10 on: February 03, 2023, 11:27:31 AM »
Not sure Grays did, but the C6+ handle wasn't too dissimilar in its method of affixation. Likewise the Newbery Hi-Tech from the 80's would have been similar, I believe.
I guess the combo of the hollowing and handle affixation makes this unique, but in isolation they're both (at first glance) concepts which have been explored.
Kai
« Reply #11 on: February 04, 2023, 11:33:26 AM »
Cool idea. Any innovations to cricket bats is always welcome with other sports taking huge strides with their equipment.
Bungle
« Reply #12 on: February 04, 2023, 05:28:48 PM »
The lawmakers may think otherwise.
thegowerwaft
« Reply #13 on: February 04, 2023, 05:55:18 PM »
This needs to be read in a Judge Dredd voice... I will get my coat.
« Reply #14 on: February 05, 2023, 07:07:24 AM »
Is part no. 9 a solid piece of wood or is it pieced together like rubber inserts of the modern handle?
If this eliminates pressure from the shoulder area which leads to cracked shoulder/hair-line splits, I think it'd save bat owners some money in the long run.
Point regarding drilling out a damaged handle is fair. How do you manage that situation? Maybe they could create a pitched thread instead of a flat hole in the bat where the handled is glued and screwed in the hole-shaft/body of the bat.
