Shin guards
Author Topic: Shin guards  (Read 2198 times)
The4thStump
Shin guards
« on: July 05, 2023, 09:35:30 PM »
Before the purists/ or the ‘just use your hands’ police get a word in, i field quite close to the square, either in slip, in batsmans eye line or in the firing line at cover/ mid wicket.
Sometimes a ball is so well struck i just stick a leg out to get anything behind the ball.
Its happened a few times and i think its time to invest in some level of protection.
Anyone tried using football or hockey shin pads? If so, any recommendations? Ive seen some fielding pads from CA and Newbery but theyre more for fielding at silly point. I want to protect my legs but still chase the ball to the boundary if needed.
Re: Shin guards
« Reply #1 on: July 05, 2023, 09:59:58 PM »
Cheap pair of football shin guards should do the trick as long as you've got a pair of socks holding the bottom of them in place. They're designed to be easy to run in after all.
Re: Shin guards
« Reply #2 on: July 05, 2023, 10:02:27 PM »
For many years this was the norm. Don't remember seeing any nasty injuries.
Re: Shin guards
« Reply #3 on: July 06, 2023, 06:11:46 AM »
Hockey shin pads would be better than football ones as they are designed for ball on leg impact.
Jaffa
Re: Shin guards
« Reply #4 on: July 06, 2023, 08:07:12 PM »
Went down to stop a ball with my hand but it bobbled and smacked into my shin. That got infected and had to be drained. Wanting to avoid the same again I managed to pick up some Stretton shin pads from ebay. Not seen them anywhere else; said to have belonged to a female pro.
Quality as you'd expect, but overkill for my level of cricket. Helped me get back into wanting the ball to come in my direction again though.
Re: Shin guards
« Reply #5 on: July 07, 2023, 06:11:27 PM »
Did some R&D with @Sivlar13 on these as an alternative to the Newbery/CA type pads mentioned earlier. These are designed for mountain biking but we looked at more robust options to insert into the pockets.
