Author Topic: Corked Cricket Bat  (Read 2550 times)
Corked Cricket Bat
« on: May 03, 2024, 12:08:34 AM »
Corked baseball bats generate better speeds than normal baseball bats. Has anyone tried to "cork" a cricket bat like a corked baseball bat? If so, what were the results?
Re: Corked Cricket Bat
« Reply #1 on: May 03, 2024, 05:22:11 AM »
Is the principle not quite similar to a laminate cricket bat?
« Reply #2 on: May 03, 2024, 07:40:37 AM »
Didn't Hunts put a hole down the middle of one of their bats, and a honeycombed back to another?
« Reply #3 on: May 03, 2024, 08:19:21 AM »
Send it didn't help baseball batters hit it further. Going back to the debate I suppose of big and light isn't better. Although there seems to be potentially perceived benefits from swinging quicker and therefore later?
https://www.technologyreview.com/2010/09/16/200387/the-misleading-myth-of-the-corked-bat/
There have been holes drilled into clefts, but this was more to just reduce weight in heavy clefts. If it seriously affected performance, every bat would be drilled out.
    • Neon Cricket
« Reply #4 on: May 03, 2024, 12:05:35 PM »
Yeah Hunts used to drill a hole through the bottom of the splice V cut down about 3/4 inches into the cleft (Turbo range), it used to take around an oz of weight out from memory. I had quite a few of them back in the day (must've been ~2014/15) and never saw it have any negative impact on performance or longevity, I know of a few still being used that came in for refurb over winter.
KettonJake
« Reply #5 on: May 03, 2024, 09:30:49 PM »
They have also corked them in the past I believe
jacob@durantcricket.co.uk
« Reply #6 on: May 03, 2024, 10:49:40 PM »
The honeycombed back might have been Slazenger.
« Reply #7 on: May 04, 2024, 06:44:23 AM »
The honeycomb was Hints.
« Reply #8 on: May 04, 2024, 11:34:41 AM »
What did it look like? (Don't say honeycomb!)
« Reply #9 on: May 04, 2024, 01:18:22 PM »
The Modulus IIRC, seem to remember it was a warranty disaster.
mr_reagan
« Reply #10 on: May 05, 2024, 04:40:51 PM »
If it doenst improve performance whats the point. Its just adding a layer of complexity for no reason. There are much easier ways to get a bat down to a playable weight
« Reply #11 on: July 26, 2024, 11:37:37 PM »
Isn't this a corked bat?
https://www.youtube.com/watch?v=f9UOtQkSPRY
Gray-Nicolls is making corked bats.
skip1973
« Reply #12 on: July 27, 2024, 03:09:53 AM »
No, there is no cork in it!
« Reply #13 on: July 27, 2024, 06:23:33 PM »
Very observant of you. There is an entire cane handle in there.
