I had an AI net...
Author Topic: I had an AI net...  (Read 4715 times)
0 Members and 36 Guests are viewing this topic.
steyn92
I had an AI net...
« on: February 22, 2026, 09:27:34 AM »
I have a few thoughts on some improvements - happy to hear others
Had it set up for Good length/back of a length bowling, changed it to good about half-way through as it was predominantly shorter.
Had a slog towards the end.
Speed was 73-75mph
Seam movement was set to 1 away
Line to Off stump - it bowls most things there, but will offer variation.
https://youtu.be/YsgnZu_qC8c?si=Tea7ZBQ4037_FL7N
mattcoll12491
Re: I had an AI net...
« Reply #1 on: February 23, 2026, 08:14:43 PM »
I’m probably not the best person to give advice. But the one thing that stands out to me, is how much you are playing outside of your eyeline when playing on the offside with little footwork.
A drill I used to use when I was coaching it getting the batter to lead with their left shoulder and lean towards cover. Over exaggerate at the beginning until it becomes natural and reduce it.
The theory was to lead with shoulder and head and the feet would instinctively move to stop you from falling over. It didn’t always work, but that’s the thing that stood out to me.
Left-Arm Curious
« Reply #2 on: March 02, 2026, 08:52:58 AM »
@steyn92 - not a coach or anything, but here's a list of things I spotted that I can see as being potential symptoms of some root technical issues:
  • Path of bat swing
  • Very little adjustment in foot movement (Potentially pre-emptive foot planting)
  • Hips seem to open up a bit too often and too soon - this means you're kind of forcing yourself to play more legside, so some of the offside shots you're offbalanced, and often playing in the air. (On the contrary, seemed to be fairly strong on the pull to midwicket.)
They say facing a bowling machine is about 5mph quicker than facing an actual bowler - if 70mph is what you'd normally face, maybe have a net at 65mph to see how you fare? (I rarely do any bowling machine work due to the availability of it) Perhaps the deliveries are a touch quicker, hence why you got into a pre-emptive footwork.
I think if I try remember back to when I've had net sessions where this has been the case, my training partner would tell me to try play beside the ball, and to hit it into the ground. If it's full, then make sure I cash out and hit it as hard as I can into the ground, while maintaining my shape. This would achieve a couple of things:
  • Would ensure I watch the path of the ball, and not get stuck on planting, as I need to get 'beside' the ball.
  • Ensure that I stay side on as long as I possibly could - this will make sure that the path of my batswing is as straight as possible
  • Would ensure that I am playing as late as possible - my goal is to hit it into the ground, and thus eliminating the risk of being caught
  • Ensure that I am confident in cashing out on the full deliveries. That's my absolute bread and butter and I want to make sure I make the most of my best scoring shot
If you join the discord and post up there, I do feel the community is a lot more responsive there than on CBF. :) Will be plenty on there to say I'm talking rubbish too I'm sure, but thought I'd stick my neck out for you here haha
alee
« Reply #3 on: April 04, 2026, 07:11:24 PM »
Try to change your bottom hand grip. Hold it with your thumb and two fingers, not the whole hand.
This way your bat face will open more and it will be easier to play straight and on offside.
The bat angle is too closed that's why everything is going onside.
