Author Topic: Routing A Bat  (Read 5405 times)
n80krr
Routing A Bat
« on: June 07, 2010, 02:09:56 PM »
Hi all I'm very new to this site and the whole bat making process, I use a 5 axis router at work so I could route pretty much any shape I wanted. I was wondering if there are any advantages to pod shaving to achieve the overall shape or would routing a bat shape be sufficient to then start to prepare the bat for it's first use. Many Thanks
Ok Ok I'll shut up
Howzat
Re: Routing A Bat
« Reply #1 on: June 07, 2010, 02:22:14 PM »
Could probably use the Router, GM use a similar CNC Router machine. I guess doing it by hand you can feel the bat at each stage, as each piece of willow has different properties.
n80krr
Re: Routing A Bat
« Reply #2 on: June 07, 2010, 02:31:24 PM »
I use a CNC router at work, I'd only use it to get the rough shape, then finish with some sanding and polishing, then a long knocking in session.
Ok Ok I'll shut up
Coach
Re: Routing A Bat
« Reply #3 on: June 07, 2010, 07:15:23 PM »
That would work, as Leo says thats what GM are using as a selling point
Tom
    • www.cricketinsight.co.uk
Re: Routing A Bat
« Reply #4 on: June 07, 2010, 07:28:42 PM »
I think at least 3 UK makers have CNC machines. They're very impressive to watch and to have 2 almost complete bats in 3 mins is amazing.
roco
Re: Routing A Bat
« Reply #5 on: June 07, 2010, 07:31:25 PM »
cnc machine are more accurate and cost a bomb especially when you break them ;)
n80krr
Re: Routing A Bat
« Reply #6 on: June 08, 2010, 05:54:15 AM »
they do require some skill, but routing wood is almost as easy as it gets. I also route polystyerene.
Ok Ok I'll shut up
roco
Re: Routing A Bat
« Reply #7 on: June 08, 2010, 12:27:36 PM »
Mine was glass and the break was not my fault thankfully the air sucker failed so glass moved and grinder went through the sucker and jerked the motor but all fun
n80krr
Re: Routing A Bat
« Reply #8 on: June 08, 2010, 12:41:18 PM »
Well at the mo I'm playing with the baby ones(2m x 4m) then if I'm any good I'll be let loose on the big one (15m x 9m). We mainly route polystyerene though, so thats much more forgiving than glass.
Ok Ok I'll shut up
roco
Re: Routing A Bat
« Reply #9 on: June 08, 2010, 12:48:58 PM »
Cool well they are fun glass is not very forgiving but rewarding as I had to go through all the programming part as well as the machine part
n80krr
Re: Routing A Bat
« Reply #10 on: June 08, 2010, 12:51:14 PM »
yeah, Fanuc is a joy to learn, as are G codes.
Ok Ok I'll shut up
roco
Re: Routing A Bat
« Reply #11 on: June 08, 2010, 12:55:24 PM »
Mine was mainly a cad cam but fun draw things on and play around on a weekend when doing a favour will always remember doing a mirror for a friend in the shape of a woman with all the features etched in was a fun Saturday morning but cnc's are mostly the same
n80krr
Re: Routing A Bat
« Reply #12 on: June 08, 2010, 01:02:38 PM »
yeah we mainly use delcam, but I have seen some cadcam. Had to make the scorpions on clash of the titans.
Ok Ok I'll shut up
norbs
Re: Routing A Bat
« Reply #13 on: June 08, 2010, 01:14:23 PM »
I bet those Scorpions "Rock you like a Hurricane"
roco
Re: Routing A Bat
« Reply #14 on: June 08, 2010, 01:21:08 PM »
Ha I like it
