Author Topic: Bowling machine knocking in  (Read 2079 times)
andeke11
« on: August 25, 2010, 03:59:45 AM »
hey guys
Just got my new SS platinum reserve of asad.
And i had training straight away so didn't have time to knock it in, for the training i spent the whole hour on a bowling machine would this be adequate knocking in or not?
cheers
Re: Bowling machine knocking in
« Reply #1 on: August 25, 2010, 08:17:31 AM »
The bowling machine uses the hard rubber balls, which are ok but not usually hard enough to help knock the bat in preoperly.
I would still tend to get a knocking in mallet on it for a couple of hours. Then use worn cricket balls in the nets and throw downs!
After all, the SS Platinum Reserve is a quality bat - would you really want to risk shortening it's life-span for the sake of a couple of hours with the mallet? Get knocking fella - better safe than sorry!  8)
andeke11
« Reply #2 on: August 25, 2010, 09:25:40 AM »
guess i got some knocking to do
cheers pete
« Reply #3 on: August 25, 2010, 09:33:57 AM »
One chap in my club once told me that bowling machine balls damage the bats. Is it true?
Andeke11 mate I am not tryin to scare you but just had this question in my mind
« Reply #4 on: August 25, 2010, 09:41:04 AM »
I think that is very unlikely, unless you are using the wrong sort of balls that a bowling machine will damage a bat. The balls are made of rubber, so should cause less damage than a normal ball. They are likely to make a mess of your bat (see this example: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=230515193653&ssPageName=STRK:MEWAX:IT) but you can clean the grey stains off, with a damp cloth is you have a scuff sheet or fine sand paper if not.
andeke11
« Reply #5 on: August 25, 2010, 09:50:44 AM »
the balls we use are good ones, so i dont think they damage my bat.
Yerr i already got some stains so cheers for that info :)
