Pages: [1] 2 3
Author Topic: Implementing Shoe Goo as a Toe Guard  (Read 10590 times)
mattw
    • PRYZM Cricket
« on: September 28, 2010, 01:36:56 PM »
I've found it tricky thus far to put shoe goo on successfully as a toe guard.
I've tried putting masking tape around the toe and then put a decent amount of shoe goo onto the toe and then evened it around to get a full cover of the toe. Since I have done that it seems as though the shoe goo has mainly edged to the sides of the bat where it is at it's lowest and left fairly faint layer on the middle of the toe.
Should I re-apply some more onto the centre of the toe and round it off once the first layer has set? As I only applied it about 10 minutes ago, should I try and shape it again now?
What's the easiest way of making sure that you have an even amount spread across the toe of the bat?
RoCo Da Pixie
Re: Implementing Shoe Goo as a Toe Guard
« Reply #1 on: September 28, 2010, 01:45:31 PM »
i like to put it on evenly and then spread it out, Making sure i have an even coating.
mattw
    • PRYZM Cricket
« Reply #2 on: September 28, 2010, 01:55:20 PM »
do it do it gradually without any tape and then spread it evenly with your fingers?
RoCo Da Pixie
« Reply #3 on: September 28, 2010, 02:07:51 PM »
i dont use tape, And i use my fingers to spread it over the toe, Messy on the fingers but easily washes off
peplow
  • Trade Count: (+77)
« Reply #4 on: September 28, 2010, 05:40:12 PM »
Put a blob on and wait for 10 or so mins, it will then not be sticky and will have begun setting so can be easily moved around and will be fine! Thats how i do it and it works and absolute treat!
iand123
« Reply #5 on: September 28, 2010, 06:18:11 PM »
Just applied my first shoe goo toe, and its a hell of alot easier than applying a toe guard (although id be the first to admit that i couldnt do this very well anyway). Applied two coats tonight and leaving to dry now. Will get some pics up once dry
mattw
    • PRYZM Cricket
« Reply #6 on: September 28, 2010, 11:50:09 PM »
nice one, would be good to see some pictures of shoe goo toe guards as I don't really know how thick to do it.
iand123
« Reply #7 on: September 29, 2010, 07:39:30 AM »
Checked it this morning and it looked good. Applied another coat as i did a thin coat first to test it out. Should be dry by tonight and i'll put pics up then
snafu
« Reply #8 on: October 27, 2010, 01:57:58 PM »
I just put some on 3 bats, 2 layers/coats/applications each how ever you describe it,it goes on like silicone,i put a line of it up the middle of the toe then wet my finger and spread it evenly around keeping the finger wet then just kept an eye on it in case it ran,after about 30 mins it was set enough to leave to harden which takes around 72hrs.i am going to put a 3rd layer on because when it dries out the moisture it shrinks down a fair bit.
I got a 110grm tube and at the rate i used it on 3 bats there should be enough for about another 6-10!!
peplow
« Reply #9 on: October 27, 2010, 02:40:18 PM »
it is fantastic value and quality for bats. Unless i have a factory fitted toe guard its shoe goo every time for me!
iand123
« Reply #10 on: October 27, 2010, 02:44:34 PM »
Agree with peplow, i am a shoe goo convert after applying it to my stick
golders
« Reply #11 on: October 27, 2010, 02:49:50 PM »
Please Can we have some pics of shoe goo bats as have not seen them before/ How much does the stuff cost?
x
niceonechoppy
« Reply #12 on: October 27, 2010, 02:49:58 PM »
I spread my Shoe Goo as I would butter on toast, with a knife....
niceonechoppy
« Reply #13 on: October 27, 2010, 02:51:30 PM »
x
Barely any cost with eBay...
http://cgi.ebay.co.uk/Shoe-Goo-1-fl-oz-Repairs-Shoes-Clear-/260677151962?pt=UK_Sporting_Goods_Skateboarding_Skating_ET&hash=item3cb191acda
golders
« Reply #14 on: October 27, 2010, 02:53:03 PM »
Ta mate
Pages: [1] 2 3
