Grip Applicators
Pages: 1 [2] 3 4 5
Author Topic: Grip Applicators  (Read 23876 times)
Coach
Re: Grip Applicators
« Reply #15 on: March 13, 2009, 10:28:02 PM »
Good old cone or a pool cue or a stump or the plastic bag have been know to be used
Jord030994
  • Ian Bell :)
« Reply #16 on: May 22, 2009, 09:08:47 PM »
Agreed'. Good, old school cone is the way to go!
Thanks, Jord :)
ianbuchanan
« Reply #17 on: May 22, 2009, 09:09:55 PM »
definately cone, but if you don't have one the plastic bag is an option! dont forget the good old broomstick trick n all!
Liam-SCCC
« Reply #18 on: May 22, 2009, 09:14:27 PM »
i have a cone and a kwick grip
use grip cone for chevrons and half grips
use kwick grip for all others as you can't use the cone for GM shock absorba or feathers, thick spirals
Top Score: 102*
Best Bowling: 7/29
AlRidd
  • Trade Count: (+15)
« Reply #19 on: June 03, 2009, 06:40:49 AM »
i managed to get a shock absorba on using my grip cone. I was sweating by the end of it
Conchord
« Reply #20 on: March 30, 2010, 02:09:17 PM »
Just used the 'plastic bag technique', took me about 20 minutes to figure out the best way of getting the bag through the grip!
However once I did it took 2 minutes to get the grip on perfectly, plus it was one of those weird GM shock absorber grips.
Definitely going to use this technique again, just so much quicker (once you figure it out!!)
Colesy
« Reply #21 on: March 30, 2010, 02:12:33 PM »
Step-by-step instructions please :)
Talisman
  • Trade Count: (+76)
« Reply #22 on: March 30, 2010, 02:15:23 PM »
I'll sell you a brand new GN gripping cone for £7.50 posted.
Colesy
« Reply #23 on: March 30, 2010, 02:17:16 PM »
I got s Shock-Absorba grip on ok with a cone. Although I'm intrigued by this plastic bag idea
Talisman
« Reply #24 on: March 30, 2010, 02:25:17 PM »
It will go on fine with a cone, plastic bag trick is sooooo odd, I've always had a cone so have never thought of fitting a grip without one.
Colesy
« Reply #25 on: March 30, 2010, 02:26:40 PM »
I find it hard to get the grip on fully, I always have a lose bit at the top causing creases when I roll the grip down the cone. Any tips? ???
christianpurchase99
« Reply #26 on: March 30, 2010, 02:28:41 PM »
gm vaccume applicator :)
"Live, Love and Burn With Zeal"
Washington
« Reply #27 on: March 30, 2010, 02:34:21 PM »
the GM vacuum applicator is good for one grip, but impossible to get a second one on!!
Formerly CustomDan21
Talisman
« Reply #28 on: March 30, 2010, 02:51:28 PM »
Just get it on the bat, roll down and then if it is short just push the roll up and down several times as it will bounce up the handle a touch, then push it all the way down and you will likely get a bit extra, do the same thing again with the main roll of grip and it will snap into place, roll up and it should be perfect.
Colesy
« Reply #29 on: March 30, 2010, 02:55:38 PM »
Cheers Mike
Pages: 1 [2] 3 4 5
