Author Topic: Using different weight bats????  (Read 2762 times)
FvanN
« on: May 23, 2012, 07:09:57 PM »
I currently own two bats, a SAF weighing in at 2.9 and a warsop venom weighing in at 2.12. Both bat are fantastic in there own way and have super ping.
I try to split my batting evenly between both bats but have found that when using the heavier warsop my batting goes out the window, apart form my under performing guns, do you guys think it is only the weight causing the problem or could it be a combination of weight and profile?
Does anybody else use different weight bats with no problems?
Talisman
  • Trade Count: (+76)
Re: Using different weight bats????
« Reply #1 on: May 23, 2012, 10:00:50 PM »
Dead weight is one factor, balance another, sometimes you can find differing combinations match up, other times the same weight and balance can feel totally different if the bats come from 2 companies.
Manormanic
« Reply #2 on: May 24, 2012, 06:50:22 AM »
agree - I mean, I have bats that range from 2lb 11 to 3lb 4 and that vary between long handles and long blades and can use all of them with pretty much the same (low) skill level.  Tends to be a horses for courses selection for me...
FvanN
« Reply #3 on: May 24, 2012, 07:07:42 AM »
Thanks for the info chaps, I dont think I will be able to use the warsop so might have to see if anybody out there has a 2.9ish bat they would swap for a 2.12 and see if that sorts out the issue as it seems a waist to have such a nice stick just sat around doing nothing. :(
« Reply #4 on: May 24, 2012, 07:32:17 AM »
My Experience has been that moving to a lighter bat has improved my batting principally due to getting to the ball quicker. This is a move from>2.12 to <2.10.
Manormanic
« Reply #5 on: May 24, 2012, 07:33:11 AM »
the other side of that though is that you might have been used to getting there at the old speed and have co**ed up your timing as a result...
« Reply #6 on: May 24, 2012, 07:48:13 AM »
Which is why I have been practising in the nets. 2.7 and below is admittedly too low and results in me rushing everything...
Simmy
« Reply #7 on: May 24, 2012, 08:09:26 AM »
im still to early on my shots using 2.14 lol so i dont think that is the issue for me lol
ajm90
« Reply #8 on: May 24, 2012, 02:15:55 PM »
maybe that your overcompensating for the increased weight?
« Reply #9 on: May 24, 2012, 02:17:52 PM »
Maybe you shouldn't think that you're playing baseball ;)
evans1234
« Reply #10 on: May 28, 2012, 09:42:06 PM »
I could not offer a bat to swap as I only have a H4L 666 weighing 2.14 but I would be interested in buying the warsop off you for a reasonable price.....
« Last Edit: May 29, 2012, 06:59:29 PM by evans1234 »
best bat: 51* best partnership:143* best bowling figures: 4-32
MJB3
« Reply #11 on: May 28, 2012, 09:44:08 PM »
The fact that the middles will be slightly different as well as balance being off affects your strokeplay
