Author Topic: New T20 style bat - First Attempt  (Read 5015 times)
Ryan
  • Trade Count: (+17)
« on: March 06, 2013, 09:48:12 PM »
I've been wanting to wake a T20 style bat for a while now so decided to give it a go last weekend.
I noticed that one of the clefts i picked up had a crack at the top which i thought would cut out in a standard length blade but it didn't. This made it the perfect candidate to become my first T20 bat. I've dropped the shoulders by around 1.5 inch and also reduced the width of the blade to 4 inch.
First thing that needed to be done after splicing and cutting the shoulders was to repair the crack.
So i decided to cut out as much of the crack i could.
Then i had to cut some spare willow to fit.
Once nice and tight i glued with some animal glue.
Then once dry i trimmed with the bandsaw before shaping with the drawknife.
Simmy
Re: New T20 style bat - First Attempt
« Reply #1 on: March 06, 2013, 09:54:34 PM »
where are the profle shots of this finished its massiveeee
Ryan
« Reply #2 on: March 06, 2013, 09:54:58 PM »
So next thing to do was to start shaping the profile.
This one was taken when it was around 3lb
Sanded, polished and binded
Stickered up
Ryan
« Reply #3 on: March 06, 2013, 09:56:44 PM »
Comparison with my match bat which weighs 2.9.5oz
« Reply #4 on: March 06, 2013, 10:00:35 PM »
Looks good ryan. What are the final specs?
« Reply #5 on: March 06, 2013, 10:04:19 PM »
Looks good mate. One question for u? What made u cut out the crack? Would it not have been better to glue it and then once shaped the bidding to the handle adding more strength? Just wondered if cutting out the damage weakens the shoulder more than a repair would have to the crack.
« Reply #6 on: March 06, 2013, 10:06:46 PM »
Top stuff mate!! How many clefts you got in atm ;)
Simmy
« Reply #7 on: March 06, 2013, 10:11:11 PM »
40mm edges 60mm spine 2.11 i think
Blazer
  • Team Anti - Concave !.
« Reply #8 on: March 06, 2013, 10:12:38 PM »
Nice work Ryan and pretty willow . I have reduced the shoulder on a bat similarly but a bit unsure about the length of the splice being shorter would increase strain on it.
« Reply #9 on: March 06, 2013, 10:13:27 PM »
Have to let us how that goes Ryan, looks like it'll be a cannon lol.
Ryan
« Reply #10 on: March 06, 2013, 10:19:43 PM »
Toe 18mm
Shoulder 18mm
Edges 40mm
Spine 55mm
Handle length around 330mm
Blade length around 520mm
Weight around 2.11.6oz haven't weighed it since gripped.
Anything else nick? Inside leg measurement or anything?
« Last Edit: March 06, 2013, 10:28:01 PM by Ryan »
Ryan
« Reply #11 on: March 06, 2013, 10:21:40 PM »
The only reason i cut the cracked section out was because it had bits missing and wanted to stop the crack from continuing down the blade. The top of the bat gets subjected to a lot of vibration so thought it was a safer bet.
« Reply #12 on: March 06, 2013, 10:28:14 PM »
essentially got a laminated shoulder so should be very strong up there as well?
looks a top bat mate, hope she serves you well :)
Ryan
« Reply #13 on: March 06, 2013, 10:30:36 PM »
I'm sure she'll be ok, i'm going to have a bash with her tomorrow - see what happens.
sgcricket
« Reply #14 on: March 07, 2013, 01:28:25 AM »
great work mate. quick question: is this bat 'laminated', as in is this bat legal?
