Author Topic: Grips sliding up  (Read 6301 times)
chaudhari21
Grips sliding up
« on: March 16, 2013, 05:52:03 AM »
I still can't seem to get this right. My bat grips always slide up the handle. I like to use two grips on my bats. I have used electric tape and cloth tape and still can't keep the grips from sliding up. Is there a way to stop this from happening?
Thanks
Sam
Re: Grips sliding up
« Reply #1 on: March 16, 2013, 06:54:45 AM »
How longs the grip been on for? Any chance it's loosened or something?
countycricketplayer
« Reply #2 on: March 16, 2013, 07:01:28 AM »
My Grips started to do that put a new grip on every 5-10 times you use it.
« Last Edit: March 16, 2013, 09:41:43 AM by countycricketplayer »
fatbats
    • Fat Bats
« Reply #3 on: March 16, 2013, 08:45:11 AM »
Happened to me and I use a small bit of superglue under bottom of grip and works a treat
johnrockin
« Reply #4 on: March 16, 2013, 09:06:30 AM »
Take the tape off. Slightly roll up the grip and apply a small amount (about 1cm) of super glue at the buttom on both sides. Roll back the grip and hold it in place for a few seconds. Replace the tape if you want.
I do it with all my bats and works very well :)
chaudhari21
« Reply #5 on: March 16, 2013, 03:36:14 PM »
Perfect thank you will try the super glue idea.
« Reply #6 on: March 16, 2013, 10:06:13 PM »
Yeah, what I would do is put the grip on, then roll it back a few cm and put some PVA or superglue and then roll it back over. :)
Nickauger
« Reply #7 on: March 16, 2013, 10:07:24 PM »
Or loosen your bottom hand on your grip!
« Reply #8 on: March 16, 2013, 10:17:05 PM »
That explains why my grips don't slide up anymore! Must be a good sign, right?! :D
Nickauger
« Reply #9 on: March 16, 2013, 10:25:18 PM »
yep
« Reply #10 on: March 16, 2013, 10:27:16 PM »
I used a lot of bottom hand, well I always though I did and my grips never come up lol
Nickauger
« Reply #11 on: March 16, 2013, 10:28:09 PM »
your grips are well applied then t-man!
« Reply #12 on: March 16, 2013, 10:29:27 PM »
Well, I am an Officer in the Grip Police so they have to be.
