Thoughts and ideas please.
Author Topic: Thoughts and ideas please.  (Read 1473 times)
fasteddie
  • Straight up.
« on: April 18, 2013, 12:47:59 PM »
Ok, so I have not got round to thinking about fixing the H4L which faste(r)eddie did a number on........
Do any of the bat makers out there fancy having a go, and can it be saved.
I've got the piece which flew out.
tbarnfield99
Re: Thoughts and ideas please.
« Reply #1 on: April 18, 2013, 12:49:19 PM »
Personally I would attempt to glue and clamp the piece into where it once was. Then I would try and put a dowel through the top and bottom and cross my fingers.
TLB
Ciaran
« Reply #2 on: April 18, 2013, 01:20:42 PM »
Im almost 100% sure that it cannot be saved.
Im guessing Matt was also of the same opinion hence you got a replacement?
dingbatsports
  • Twitter: @dingbatsports
    • Dingbat Sports
« Reply #3 on: April 18, 2013, 01:40:05 PM »
Could be saved by either gluing the old piece back in, or grafting in a new piece of willow. A dowel would hold it in place :)
Dan W
« Reply #4 on: April 18, 2013, 01:43:45 PM »
Look forward to it appearing in the sale/swap section "superficial damage near the toe, and repaired by the top batmaker, and a dowel inserted only as a precaution..."
fasteddie
  • Straight up.
« Reply #5 on: April 18, 2013, 02:06:11 PM »
Gary @Choice gave it last rites, but I'm interested in exploring the options. It might be worth spending a few £'s and I might get lucky.
snafu
« Reply #6 on: April 18, 2013, 02:07:02 PM »
R I P
snafu
« Reply #7 on: April 18, 2013, 02:08:34 PM »
Shorten it and make it into a catching bat
« Reply #8 on: April 18, 2013, 02:10:47 PM »
Pedals bat was fixed and it was similar to this. Pretty sure if you still have the piece and you get it glued into place and dowelled it my hold for a while, but obviously there will be no set time it will hold and may blow out at any time
Ryan
  • Trade Count: (+17)
« Reply #9 on: April 18, 2013, 02:34:36 PM »
I'd square it off and make a fielding bat for catching practice.  I don't think it's worth repairing.  Once the toe goes it's hard to repair due to the vulnerability of the area. The toe receives a lot of abuse.
i12breakfree
« Reply #10 on: April 18, 2013, 02:44:25 PM »
shorten the blade
get a longer handle - ur new T20 bat is ready
fasteddie
  • Straight up.
« Reply #11 on: April 18, 2013, 03:02:02 PM »
Good advice.
I think I will go down that route.
I'll post a pic when it's done.
