My Salix Pod returns!
Author Topic: My Salix Pod returns!  (Read 2260 times)
beaver5
« on: May 24, 2013, 11:44:31 AM »
My much loved Salix Pod has sat in the loft for over a season or so now consigned to the scrapheap with 2 large cracks by the handle and blade. I took it to Roger Weston at Solitaire to see if he'd have a look. He said the handle needed replacing and he could glue the cracks at the top of the blade. It's a bit of a risk as it could be a waste of money because it could brake very quickly, but equally it might last. For £35 as opposed to nearly £400 for a new one I felt it was worth a go. After all it was a truly special bat. He's done an amazing job on it and I added the remaining stickers I had left over from a previous refurb. I have to say I think it looks stunning and I'm over the moon with the final result. Just have to keep my fingers crossed now.
400notout
Re: My Salix Pod returns!
« Reply #1 on: May 24, 2013, 11:45:47 AM »
Looks like a not bad job, hope it lasts out a while! What weight is it at now?
I'm the first one to turn away big edges, but that does look featherlight?!
Boff
« Reply #2 on: May 24, 2013, 11:51:45 AM »
thats a good looking refurb - bargain.
risk definately worth taking
beaver5
« Reply #3 on: May 24, 2013, 11:52:24 AM »
Its just under 2.8 and like a wand
nudgemaster
« Reply #4 on: May 24, 2013, 12:45:40 PM »
Looks lovely.
Good wood saved from the scrapheap.... Credit to all involved.
74           6/27
SkipperJ
« Reply #5 on: May 26, 2013, 06:05:52 AM »
b5, would you have a closeup of the cracks? thanks
CBF gave me BAD real bad!
beaver5
« Reply #6 on: May 26, 2013, 10:53:23 AM »
I'll try sort some out. Will post after played today.
beaver5
« Reply #7 on: May 27, 2013, 07:18:47 AM »
A close up of the crack. Hope it holds. Seemed to go ok yesterday.
SkipperJ
« Reply #8 on: May 30, 2013, 02:00:15 AM »
Crack doesn't look too bad mate. If you like, you could bind the shoulder with twine, but it should be fine without.
beaver5
« Reply #9 on: June 20, 2013, 07:33:12 PM »
Just thought I'd give an update on how the repaired pod's going. Played a few weeks ago and hit one right up by the shoulder crack. Sounded bad so swopped bats mid innings as thought it had gone. After getting it home saw that crack hadn't got any bigger so decided to give it another go. Played last night and it sure isn't broke! Hit 51 off 33 balls, including 3 sixes, one of which was the biggest I've ever hit. Cleared the top of an oak tree well outside the boundary.  Looks like money well spent.
