Author Topic: Can I use this glue to fix few cracks on a bat?  (Read 2551 times)
mini998
« on: July 24, 2013, 03:21:53 PM »
It doesn't say this is PVA based , shop assistant said this is stronger than PVA so not sure what to buy...
If this doesn't work then what make/brand of glue I should be buying?
ajmw89
  • 4XI ornament
    • Wright Cricket
Re: Can I use this glue to fix few cracks on a bat?
« Reply #1 on: July 24, 2013, 03:26:00 PM »
Get the weatherproof one.  That's what I use
mini998
« Reply #2 on: July 24, 2013, 03:30:47 PM »
You mean the exact same brand as the picture?
Blue one is weatherproof, so I'll buy that one then. BTW shop assistant said this is not PVA based though
ajmw89
  • 4XI ornament
    • Wright Cricket
« Reply #3 on: July 24, 2013, 03:41:39 PM »
I have a bottle of that at the moment.  So long as it is wood glue and water/weatherproof it should do the trick.  haven't had anything I've glued recently come apart yet.
mini998
« Reply #4 on: July 24, 2013, 04:00:43 PM »
Thanks, bought one of them.
patriotscreen
« Reply #5 on: July 24, 2013, 06:26:00 PM »
Having said that, I use the normal interior one and never had any problems with anything coming unstuck even after oiling, sanding, knocking, more oiling
Cricklade 2nd XI
Russ
ajmw89
  • 4XI ornament
    • Wright Cricket
« Reply #6 on: July 25, 2013, 08:41:54 AM »
It shouldn't come unstuck, but I'd rather have the extra peace of mind that I've used weather/waterproof glue.
mini998
« Reply #7 on: July 25, 2013, 08:57:21 AM »
One last question guys,
Can I dilute this glue with water to make it easier to run down cracks?
ajmw89
  • 4XI ornament
    • Wright Cricket
« Reply #8 on: July 25, 2013, 09:04:00 AM »
Yeah, you can.  Don't over dilute it though, otherwise it won't hold.  You shouldn't need too much water
mini998
« Reply #9 on: July 25, 2013, 09:13:28 AM »
^ Thanks
« Reply #10 on: July 25, 2013, 09:55:51 AM »
Expensive isn't it?
How much of it do you get through?
I've got a huge vat of PVA that wasn't much more than this. I've never had a complaint about a repair not holding.
ajmw89
  • 4XI ornament
    • Wright Cricket
« Reply #11 on: July 25, 2013, 10:11:28 AM »
I've got a big vat on it's way to me.  had a lot of broken bat toes from guys at my club to repair recently and ran out in the middle of repairing one, so had to nip down B&Q to get a bottle.  I keep hold of the bottle though, as the nozzle is useeful for squeezing glue into cracks.  Just refill the bottle from the tub when it's empty.
« Reply #12 on: July 25, 2013, 10:14:16 AM »
I use printer ink refill needles to get the glue into the tiniest of gaps - maybe I'm a bit OTT but it works brilliantly!
ajmw89
  • 4XI ornament
    • Wright Cricket
« Reply #13 on: July 25, 2013, 10:46:06 AM »
I'll bear that in mind.  I've also tried piping glue in the way you would with icing on a cake and a very fine nozzle.  Works well, but can be quite messy if the glue is watered down!
« Reply #14 on: July 25, 2013, 02:57:41 PM »
If it is a long crack that is still quite closed up, there was a tip to squeeze some glue in the crack after making it a little wider, then use a straw to blow down which should get the glue right deep into the clack?
I thought that sounded like a decent idea!
