DIY Cracked Toe Repair
Author Topic: DIY Cracked Toe Repair  (Read 3598 times)
EaglesCC
« on: October 15, 2013, 03:41:46 PM »
Picked this bat up from Steve MSR via one of his eBay listings as a net/ wet weather bat.
It's new but has a crack on the toe towards the back/ edge of the blade. Wondering if I should DIY repair this or possibly needs so professional attention?
jwebber86
Re: DIY Cracked Toe Repair
« Reply #1 on: October 15, 2013, 05:21:44 PM »
sorry i cant be much help with the toe. but i also bought a bat from his ebay listing a while ago which had a split in the shoulder was a bargain at £26 for a net bat.
just wondering what you thought of the actual bat though
@james_webber
@dunstercricket
simonmay5
« Reply #2 on: October 15, 2013, 05:36:17 PM »
Open crack and glue and clamp or it might need a dowel in their
Ryan
  • Trade Count: (+17)
« Reply #3 on: October 15, 2013, 05:40:26 PM »
I wouldn't do anything with it until the crack opened up more.  Otherwise you could damage it when forcing it open.
joeljonno
« Reply #4 on: October 15, 2013, 06:23:36 PM »
If it is a net bat, there is little point spending a lot of money on a professional fix, unless you have one very local to you.
I would do it yourself.
Whether to do it now or wait as per Ryan, that would be up to you.
Twitter - @joeljonno
EaglesCC
« Reply #5 on: October 15, 2013, 07:29:04 PM »
I had a look at the pics in your other post but can't really make out the crack...? Did you pay £26 inc delivery? How long has it lasted?
I had a cheap MSR before which was again massive for the size but split from the toe upwards. It was over dried.
This one is no exception; 2lb 8.5oz inc the grip bit massive edges and reasonable spine.
I was thinking that initially...
...But I'm inclined to agree with you here Ryan as although it moves ever so slightly when pressed I think it would split completely if I tied to prise it apart to glue.
Problem is I wanted to add a toe guard as it's like to be a wet weather/ all surface bat should I refrain from doing that?
Vulcan Cricket
« Reply #6 on: October 15, 2013, 07:37:21 PM »
pop it over to me ill fix it for u
EaglesCC
« Reply #7 on: October 15, 2013, 07:46:48 PM »
Thanks, appreciate the offer however as said it will become uneconomical by the time postage etc is added.
Would end up costing what a normal lower grade might cost from MSR...
Was hoping I could get some advice about risking it or a DIY fix
« Last Edit: October 15, 2013, 07:49:43 PM by EaglesCC »
« Reply #8 on: October 15, 2013, 08:38:33 PM »
I'd be inclined to open the crack slightly (if possible) fill with watered down glue and clamp. Then put a dowel in there and wrap tightly with tape.
Blazer
  • Team Anti - Concave !.
« Reply #9 on: October 15, 2013, 08:50:05 PM »
I have used a couple sewing pins to gently wedge the crack open and use some diluted glue, and clamped it using cut rubber grips. I find spiral grip rings the best to use.
Ryan
« Reply #10 on: October 15, 2013, 08:56:39 PM »
Why don't you try dropping some watered down pva or superglue down the crack.  Or you could glue it back on if it does fall off or get worse.
EaglesCC
« Reply #11 on: October 16, 2013, 02:48:36 PM »
I may just try some watered down glue and some tape. I guess for the price it wouldn't be too upset if the piece came off and I had to glue it back on.
jwebber86, to answer your question - the bat responds well off the ballet but I'm glad I bought a light weight as the pick up is about it's weight. Which is a little surprising given the high middle. I remember the one I had before being all round a really good bat. Would be interested to hear how yours plays.
